Can I change a project name without changing the authorization key? I’m doubting it, but it would be great if there was a way. My simple “LED” program has grown immensely and deserves a better name
I want to proceed cautiously here because the Arduino is about 90 miles from home, so I obviously can’t just run over there to change the key if that’s what’s required.
More importantly, can I use a project as a template to create a new project? (not cloning / sharing with someone else). Any help / advice here would be very appreciated.
Worked as you said - just didn’t want to risk losing my connection at the other end. Thanks! I’m monitoring air conditioning performance (vent and room temperature) as I control the unit 90 miles away. Maybe I’ll reach a point soon where I can share it.
