Changeing a physical joystick to a Blynk joystick
the code I pasted bellow is my code for a pan/tilt that is ran off of a physical joy stick. I have my Bluetooth code figured out and connected to my phone. I was wondering how I would change the physical joystick to a virtual joystick. Once that is figured out I will past it into the Bluetooth code.
pinMode(5, OUTPUT); //we have to set PWM pin as output
pinMode(6, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
int joyXIn = analogRead(0); //Read the joystick value
int joyYIn = analogRead(1); //Read the joystick value
int joyX = map(joyXIn, 0, 1023, -255, 255); //Map joystick imput so it will work the servo motor
int joyY = map(joyYIn, 0, 1023, -255, 255); //Map joystick imput so it will work the servo motor
if (joyX < 0)
digitalWrite(3, HIGH);
analogWrite(5, joyX * -1);
if (joyX < 0)
digitalWrite(4, LOW);
analogWrite(6, joyY * -1);
if (joyX > 0)
digitalWrite(3, LOW);
analogWrite(5, joyX);
if (joyY > 0)
digitalWrite(4, HIGH);
analogWrite(6, joyY);
Take a look at the example page http://examples.blynk.cc/ under Widgets/JoystickTwoAxis.
