Change SuperChart Line Color with Node-RED
Is it possible to change the SuperChart line color by changing a property in Node-RED?
Setting the color property (msg.color) works for all other widgets.
I don’t think it’s possible.
Node-Red just gives the same functionality as the Blynk.setProperty command in code, and I don’t think it can be done from there either:
