I would like to change my local server with a more powerful one. can it be done without losing the data? Are there any folders to save and import into the new server?
Thank!!!
Thank!!!
Yes. Those you specified via -dataFolder
param. You need just copy it.
I did this recently - all you need to do is make sure the prerequisites are installed on the new server and copy your Blynk directory across (I had my config, server file and data directory in one folder).
