Hi friends. is any example to change eventor values with slider widget ?
thanks
thanks
thanks. but when I set slider there is no change in values in eventor. for example I set the slider to 16 but in eventor there is no change. I want to set V10 with slider to 16 and set the when V10 is higher than 17 than V11 to 1.
eventor never change value , the value are fixed
eventor is juste like if conditions in code
to do what you want , you have to write code, very easy !
yes I want it in sketch. can you show an example code for me? .thanks
yes but explain what is V10 and V11 and what’s supposed to do for you
take a screenshot
just I want set any values to eventor with slider widget.
you can’t do that !
I repeat, eventor is just like “if conditions”
Ok thanks.
you have to code your conditions to do anything you want to see when you slide the slider widget
