Can't sync GPIO state to widget button
Hi friends. I want to sync GPIO state with the widget button but can’t working. in the blow sketch when pirPin set to high then GPIO 4 (D2) go to low but the widget button (D2) can’t be sync.
#include <SI7021.h>
#include <Wire.h>
#include <Adafruit_BMP085.h>
#include <BH1750.h>
BH1750 lightMeter;
char auth[] = "fe5078fcb5f04f5384ac70cb9ab91697";                 //Put your blink token
char ssid[] = "MikroTik Tesla";                            //Put your SSID of your connection
char pass[] = "12345678";                            //Put your Password of your connection
char server[] = "10.5.50.18";
SI7021 sensor;
#define I2C_SCL 12      //D6
#define I2C_SDA 13     //D7
#define ledPin 15
#define alarmPin 4
#define pirPin 14
Adafruit_BMP085 bmp;
float dst, bt, bp, ba, q;
char dstmp[20], btmp[20], bprs[20], balt[20];
bool bmp085_present = true;
int pirState;
int val;
int x;
BLYNK_CONNECTED() {
      Blynk.syncVirtual(V0);
BLYNK_WRITE(V0){
 x = param.asInt();
void PIRval(){
val = digitalRead(pirPin);
    if (val == HIGH) {
      digitalWrite(ledPin, LOW);
      else {
        digitalWrite(ledPin, HIGH);
  void pir(){
  if (x == 1){
    if (digitalRead(pirPin) == HIGH){
 Blynk.notify("Alarm Enabled");
 digitalWrite(alarmPin, LOW);
  Serial.begin(115200); // See the connection status in Serial Monitor
  Blynk.begin(auth, ssid, pass, server, 8080); //insert here your SSID and password
  Wire.begin(I2C_SDA, I2C_SCL);
if (!bmp.begin()) {
  Serial.println("Could not find a valid BMP085 sensor, check wiring!");
  //while (1) {}
  timer.setInterval(1000L, PIRval);
  timer.setInterval(1000L, pir);
  lightMeter.begin();
  //sensor.begin(SDA,SCL);
  pinMode(ledPin, OUTPUT);
  pinMode(alarmPin, OUTPUT);
  pinMode(pirPin, INPUT);
  digitalWrite(alarmPin, HIGH);
void sendUptime()
  float temperature = sensor.getCelsiusHundredths();
  float humidity = sensor.getHumidityPercent();
  Blynk.virtualWrite(5, (float)temperature/100);
  Blynk.virtualWrite(6, humidity); // virtual pin
  uint16_t lux = lightMeter.readLightLevel();
  Blynk.virtualWrite(4, lux);
  float bp =  bmp.readPressure();
  Blynk.virtualWrite(9,(float)bp/100);
  float ba =  bmp.readAltitude();
  Blynk.virtualWrite(7, ba);
  float bt =  bmp.readTemperature();
  Blynk.virtualWrite(12, bt);
  float dst =  bmp.readSealevelPressure(520)/100;
  Blynk.virtualWrite(13, dst);
  float q = analogRead(A0);
  Blynk.virtualWrite(2, q);
  float val = digitalRead(pirPin);
  Blynk.virtualWrite(3, val);
You need to set the virtual button low as well, Blynk.virtualWrite(VX, 0); after you change your GPIO4
