Can't show values from a Fishino Mega V2
Hello everyone, me and my friend are working on a greenhouse project.
We’re using Fishino Mega v2, integrated with a ESP8266 Wifi module. We success to connect it to the Router, but it doesn’t show the values to the app and after 2 loops it disconnect from it without succeeding anymore,
It is supposed to read from a light sensor the values and show it to Blynk (“light1”).
Here’s part of the code.
//Librerie
#include <Fishino.h>
#include <FishinoFlash.h>
#include <BlynkSimpleFishino.h>
//Sensori Lampada
#define LGTS1 A0
//Valori Blynk
char auth[] = "FXm0rf********************************dE4";
//Paramentri Wifi
#define MY_SSID "FRITZ!Box 7530 FI"
#define MY_PASS "****************************"
int CrepuValue1 = 0;
int media_L;
void StatoLuce(void) //Stato: OK
  CrepuValue1 = analogRead(LGTS1);
  ligth1 = map(CrepuValue1, 0, 760, 0, 100);
  Serial.println("Avviamento setup()");
  pinMode( CrepuValue1, INPUT);
  Blynk.begin(auth, MY_SSID, MY_PASS);
  //Wifi
  Serial << F("Reset WiFi in corso...");
  SPI.begin();
  SPI.setClockDivider(SPI_CLOCK_DIV2);
  while (!Fishino.reset()){
    Serial << F("(riprova)");
  Serial << F("OK\n");
  Fishino.setMode(STATION_MODE);
  Fishino.setPhyMode(PHY_MODE_11G);
  Serial << F("Connessione sull'AP...") ;
  while (!Fishino.begin(MY_SSID, MY_PASS))
    Serial << F(".");
    delay(2000);
  Serial << F("Collegamento riuscito\n");
#ifdef IPADDR
  Fishino.config(ip, gw, nm);
#else
  Fishino.staStartDHCP();
#endif
  Serial << F("In attesa per l'IP...");
  while (Fishino.status() != STATION_GOT_IP){
    Serial << F(".");
    delay(500);
  Serial << F("\n");
  Serial << F(" - SSID  : ") << MY_SSID << "\n";
  Serial << F(" - IP    : ") << Fishino.localIP() << "\n";
  Serial << F(" - Segnale: ") << Fishino.RSSI() << "\n";
  Serial << F(" - Setup OK\n");
  //end setup ***********************************************************
  Serial << F(" - initiation OK\n");
  Serial << F("setup() concluso, avviamento loop(). OK\n");
  Serial << F("\n*************************************\n");
 StatoLuce();
 Serial.println(" ");
I don’t think you can do both of these.
I’m assuming that the device is connecting to WiFi & Blynk, then that connection being immediately terminated because of the Fishino.begin command.
