Make sure you are not using the BLYNK_READ() function, as that function requires the widget to control the reading rate and thus only works when the App is active
Use virtual pins and PUSH mode in the App widgets, and on your device use BlynkTimer and timed functions for your sensor reading and Blynk.virtualWrite() commands, then your device will continue to send data to the server regardless if the App is on or not.
And when you open your App you will see the updated info, as it is always stored on the server not the App.
by ‘off’ do you mean the app is not in run mode (but in ‘edit’ mode) ?
In the app, leave it running, not in edit mode. You can close Blynk on the phone and even power the phone off, and the code in the ESP should still communicate to the Blynk server.
