Hello, I would like some help with my project !!!
I have an Arduino board doing a certain job and displaying some data on an LCD. All fine up to that.
What I would like, is to also display that data on my phone over the Internet.
I’ve used Blynk before to control and read hardware pins, but what I want to now is this:
I need a way to SEND DATA (specifically 3 or 4 float numbers) from my Arduino to my ESP8266 over SERIAL. Then I want to Write that data on a VIRTUAL Pin so I can display them on my Blynk app.
I’ve searched online and found a way of reading Serial Data.
This is how far I’ve gotten up till now…:
#define BLYNK_DEBUG
const byte numChars = 32;
char receivedChars[numChars];
boolean newData = false;
int dataNumber = 0;
char auth[] = "***************************************";
char ssid[] = "*********";
char pass[] = "********";
int test;
timer.setInterval(500L, recvWithStartEndMarkers);
timer.setInterval(500L, showNewNumber);
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
void showNewNumber() {
if (newData == true) {
dataNumber = 0;
dataNumber = atoi(receivedChars);
newData = false;
Blynk.virtualWrite(2, dataNumber);
/* test=random(50, 200);
Blynk.virtualWrite(1, test);
Serial.println("hi"); */
/* This is actually used for testing. The VirtualWrite works flawlessly, but the SerialPrint does not print most of the time on my Serial Monitor. */
Most of the time, I can’t get the Serial.println(); commands to actually print something on my serial monitor, and I can’t get the ESP8266 to actually read Serial Data no matter what.
The Virtual Write command though, works as it should. Giving me a random number every run.
I’m quite new to programming and Arduinos so my knowledge is quite limited.
I’ve searched all night for this with no luck.
I would greatly appreciate your help ! <3
PS. I tried typing values through my Serial Monitor while the ESP8266 was connected and I also tried connecting it to a second Arduino that Serial Printed values in this format: where x is a number.
