Can't create new project
I created my local blynk server, everything works fine, but now I can’t create a new project from Android app. App said: “Project could not be created. Please wait until token will be received.”.
In my blynk.log:
ERROR - Input command is invalid. Closing socket. Reason cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command not supported. Code : 42. Address /185.143.116.27:36892
Server version is 0.21.1, app - 2.1.0. Thanks.
Hello. Please try to remove and install app again. It could be cache issue.
This solution doesn’t work.
When I opened created project in app I see info: “Reconnecting to the server…”.
Server logging still the same issue continuosly.
07:39:26.898 INFO - patryk0493@gmail.com app joined.
07:39:27.375 ERROR - Input command is invalid. Closing socket. Reason cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command not supported. Code : 42. Address /185.143.116.27:57758
07:39:27.633 INFO - patryk0493@gmail.com app joined.
07:39:29.320 ERROR - Input command is invalid. Closing socket. Reason cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command not supported. Code : 42. Address /185.143.116.27:46294
07:39:30.496 INFO - patryk0493@gmail.com app joined.
07:39:31.091 ERROR - Input command is invalid. Closing socket. Reason cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command not supported. Code : 42. Address /185.143.116.27:38662
Please make sure you are running latest server. Use
ps -aux | grep java
and show here output.
