Im sorry actually i am really tensed about ths project
Your code is missing the Template ID, and this needs to be the first line of your sketch.
@PeteKnight i have added it and still im getting same error and im using arduino web editor as i have messed up my libraries for my arduino IDE
Blynk is a platform with iOS and Android apps to controlA
Follow us: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example shows how to use Arduino MKR 1010
to connect your project to Blynk.
Note: This requires WiFiNINA library
from http://librarymanager/all#WiFiNINA
Feel free to apply it to any other example. It's simple!
/* Fill-in your Template ID (only if using Blynk.Cloud) */
#define BLYNK_TEMPLATE_ID "TMPLUYa6cPOC"
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
char auth[] = "zbCT06aAvqEJDyqXi1F7Q-246ZstsE8S";
char ssid[] = "AGP-Jr-Wi-Fi";
char pass[] = "";
Using library wifinina_1_8_13 at version 1.8.13 in folder: /home/builder/opt/libraries/wifinina_1_8_13
Using library blynk_1_0_1 at version 1.0.1 in folder: /home/builder/opt/libraries/blynk_1_0_1
In file included from /home/builder/opt/libraries/blynk_1_0_1/src/Blynk/BlynkApi.h:36:0,
from /home/builder/opt/libraries/blynk_1_0_1/src/BlynkApiArduino.h:14,
from /home/builder/opt/libraries/blynk_1_0_1/src/Adapters/BlynkWiFiCommon.h:24,
from /home/builder/opt/libraries/blynk_1_0_1/src/BlynkSimpleWiFiNINA.h:22,
from /tmp/642170011/Arduino_MKR1010_copy/Arduino_MKR1010_copy.ino:41:
/home/builder/opt/libraries/blynk_1_0_1/src/Blynk/BlynkParam.h: In member function 'long long int BlynkParam::iterator::asLongLong() const':
/home/builder/opt/libraries/blynk_1_0_1/src/Blynk/BlynkParam.h:48:50: error: 'atoll' was not declared in this scope
long long asLongLong() const { return atoll(ptr); }
/home/builder/opt/libraries/blynk_1_0_1/src/Blynk/BlynkParam.h:48:50: note: suggested alternative: 'atol'
atol
/home/builder/opt/libraries/blynk_1_0_1/src/Blynk/BlynkParam.h: In member function 'long long int BlynkParam::asLongLong() const':
/home/builder/opt/libraries/blynk_1_0_1/src/Blynk/BlynkParam.h:89:46: error: 'atoll' was not declared in this scope
long long asLongLong() const { return atoll(buff); }
/home/builder/opt/libraries/blynk_1_0_1/src/Blynk/BlynkParam.h:89:46: note: suggested alternative: 'atol'
atol
Error during build: exit status 1
@ZAID if you continue to post questions about the same issue in multiple topics then your forum account will be suspended.
Please consider this to be your last warning about this.
@ZAID first Add BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME on top of your firmware, above any includes.
Second please listen to Pete advice.
@PeteKnight im just trying to find answers
i didnt realize the confusion this would cause.
i wont repeat it
@John93 is this the correct way??
#define BLYNK_DEVICE_NAME "Quickstart Device"
char pass[] = "";
i am getting the same error
How did you get the auth token ?
Yes that’s right, now everything should work just fine.
People could you tell me if anybody alreday solve this issue on UNO WIFI REV 2, where just compile on BLYNK version 6.01, but did not work with blynk IOT, becasue said Invalid auth token, and when we use last version of blynk DID NOT COMPILE
this is very fraustration, becasue i have a lot of project associated to UNO WIFO REV 2
anybody can help please?
thanks a lot for any help.
The 0.6.1 library will always try to connect to the Legacy Blynk servers, unless you specifically tell it not to. This means that when it tries to pass the Blynk IoT auth token to the Legacy server it won’t recognise the token.
I don’t think that trying to force the 0.6.1 library to connect to the new IoT cloud servers is the correct solution.
Without knowing more about your particular compiler error messages, along with which version of the WiFiNINA library you have installed, and how exactly you installed that library, then it’s very difficult to comment in a constructive way.
Pete
always present thanks a lot for your answer
WIFiNINA Library i am use 1.4.8. last update
errors after compile here
Arduino: 1.8.16 (Windows Store 1.8.51.0) (Windows 10), Placa:“Arduino Uno WiFi Rev2, ATMEGA328”
In file included from C:\Users\EliteBook 8560\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:36:0,
from C:\Users\EliteBook 8560\Documents\Arduino\libraries\Blynk\src/Blynk.h:14,
from C:\Users\EliteBook 8560\OneDrive\Documentos\PROJECTOS ARDUINO\TESTE_WIFI_conecttion_BLYNK\TESTE_WIFI_conecttion_BLYNK.ino:27:
C:\Users\EliteBook 8560\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h: In member function ‘long long int BlynkParam::iterator::asLongLong() const’:
C:\Users\EliteBook 8560\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:48:50: error: ‘atoll’ was not declared in this scope
C:\Users\EliteBook 8560\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:48:50: note: suggested alternative: ‘atol’
atol
C:\Users\EliteBook 8560\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h: In member function ‘long long int BlynkParam::asLongLong() const’:
C:\Users\EliteBook 8560\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:89:46: error: ‘atoll’ was not declared in this scope
C:\Users\EliteBook 8560\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:89:46: note: suggested alternative: ‘atol’
atol
exit status 1
Erro ao compilar para a placa Arduino Uno WiFi Rev2.
