I setup a local Blynk server on a Raspberry Pi and got it running and created a new login account. I’m having issues connect to the hardware now. I turned on the #define BLYNK_DEBUG
and this is the output I get from the console:
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.5.1 on Teensy 3.5
[910] Connecting to SSID
[4113] AT version:1.2.0.0(Jul 1 2016 20:04:45)
SDK version:1.5.4.1(39cb9a32)
Ai-Thinker Technology Co. Ltd.
Dec 2 2016 14:21:16
OK
[9335] +CIFSR:STAIP,"192.168.1.105"
+CIFSR:STAMAC,"XX:XX:XX:XX:XX:XX"
[9335] Connected to WiFi
[19432] <[02|00|01|00] THIS PART PRINTS MY AUTH TOKEN
[29636] <[02|00|01|00] THIS PART PRINTS MY AUTH TOKEN...
I’m on the same wifi as the raspberry pi and input the local IP address on my Blynk.begin()
code:
Blynk.begin(auth, wifi, ssid, pass, "192.168.1.140");
I’m also a little confused about which port I should be using. Currently I’m using 9443 but I saw in videos they used 8443 and others. Should I also be specifing the 9443 port in the Blynk.begin
code?
Here are the ports from the server.properties file:
#hardware mqtt port
hardware.mqtt.port=8440
#hardware ssl port
hardware.ssl.port=8441
#http, plain web sockets and plain hardware port
http.port=8080
#secured https, web sockets and app port
https.port=9443
#application ssl port
app.ssl.port=8443
#address to bind to. by default bounded to all interfaces
listen.address=
I’m trying to connect to a Teensy 3.5 with ESP8266 wifi controller but haven’t been able to connect yet.
