Compiling an example for esp32 and get this error (all examples gives the same error):
Using board ‘canmod_mini_v2’ from platform in folder: /Users/meg/Documents/ArduinoSketches/hardware/espressif/esp32
Using core ‘esp32’ from platform in folder:
/private/var/folders/3q/c4hlcgyn17q8rrwdv23bcvbw0000gn/T/arduino-sketch-34769411EF95ECC57F62D06DAC30C26C/sketch/ESP32_WiFi.ino.cpp -o /private/var/folders/3q/c4hlcgyn17q8rrwdv23bcvbw0000gn/T/arduino-sketch-34769411EF95ECC57F62D06DAC30C26C/sketch/ESP32_WiFi.ino.cpp.o
In file included from /Users/meg/Documents/ArduinoSketches/hardware/espressif/esp32/cores/esp32/esp32-hal-gpio.h:29,
from /Users/meg/Documents/ArduinoSketches/hardware/espressif/esp32/cores/esp32/esp32-hal.h:79,
from /Users/meg/Documents/ArduinoSketches/hardware/espressif/esp32/cores/esp32/Arduino.h:36,
from /private/var/folders/3q/c4hlcgyn17q8rrwdv23bcvbw0000gn/T/arduino-sketch-34769411EF95ECC57F62D06DAC30C26C/sketch/ESP32_WiFi.ino.cpp:1:
/Users/meg/Documents/ArduinoSketches/libraries/Blynk/src/BlynkApiArduino.h: In member function ‘void BlynkApi::processCmd(const void*, size_t)’:
/Users/meg/Documents/ArduinoSketches/hardware/espressif/esp32/variants/canmod_mini_v2/pins_arduino.h:10:48: error: ‘esp32_adc2gpio’ was not declared in this scope
#define analogInputToDigitalPin(p) (((p)<20)?(esp32_adc2gpio[(p)]):-1)
/Users/meg/Documents/ArduinoSketches/libraries/Blynk/src/BlynkApiArduino.h:69:62: note: in expansion of macro ‘analogInputToDigitalPin’
#define BLYNK_DECODE_PIN(it) (((it).asStr()[0] == ‘A’) ? analogInputToDigitalPin(atoi((it).asStr()+1)) : (it).asInt())
/Users/meg/Documents/ArduinoSketches/libraries/Blynk/src/BlynkApiArduino.h:92:25: note: in expansion of macro ‘BLYNK_DECODE_PIN’
const uint8_t pin = BLYNK_DECODE_PIN(it);
^~~~~~~~~~~~~~~~Using library WiFi at version 2.0.0 in folder: /Users/meg/Documents/ArduinoSketches/hardware/espressif/esp32/libraries/WiFi
Using library Blynk at version 1.1.0 in folder: /Users/meg/Documents/ArduinoSketches/libraries/Blynk
exit status 1Compilation error: exit status 1
