Hello there …
i am working on esp8266 and laravel . i want to make the project dynamic . So can we make datastream using API?
Not currently.
No idea if its something that’s in the pipeline, but there are potentially other things you could do, like using Alias Names that may be a workaround.
but still i will use blynk console create datastream first then i will work on it. but i want to create things on run application.
I understand that.
so right now there is no solution to my problem sir…
