Can we bridge?
Out of curiosity i uploaded same code to two different nodemcu with pushbutton and relay hooked up . And also with same auth token. ( two identical setup ) .
When i turn on or off a relay with blynk app it just turns on and works with only nodemcu ! Why not both ? But pressing the physical button on the 2nd nodemcu will reflect on the app ! But doesn’t turn on the 1st nodemcu !
As this is all running on the same server and auth token it should be in the same circuit or loop right !?
Or am i wrong in this ?
If I want this to get working with what possible way can be used ? ( Bridge in blynk ) can be used ?
yes, better use bridge widget
