Can we access blynk server as well as blynk server app on mobile?
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
The App runs on your mobile and accesses the server (Cloud or Local) all the time, at least it needs to in-order to function, so… Yes…
Perhaps you can clarify your question?
