Can the virtual pin value be kept when device disconnected from wifi?
I am using a virtual pin V8 to store the water level by counting the motor ON time.
Initial value of V8 = 1000 (i.e. max water level)
when I turn on motor for 3 sec, V8 will be 997
when I turn on motor for 5 sec, V8 will be 992, etc.
However, in reality, the device may be disconnected from the wifi for a while, the value of V8 will be backed to 1000, is any method that I can keep the value of V8 even disconnect from wifi?
Below is my coding
//  LIBRARY
#include <ESP8266_Lib.h>
//  DEKLARASI AWAL
char auth[] = "";
char ssid[] = "";
char pass[] = "";
#define EspSerial Serial3
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
//BLYNK_WRITE(V0)
//  drink = param.asInt();
int pump_on;
int interval;
int interval1;
int timer_no;
int drink_level1 = 1000;
BLYNK_WRITE(V6)
  pump_on = param.asInt();
  if (pump_on == 1)
  digitalWrite(52, HIGH);
  timer_no = timer.setTimeout(interval1, []()
  digitalWrite(52, LOW);
  Blynk.virtualWrite(V6, 0);
  drink_level1 = drink_level1 - interval;
  else {digitalWrite(52,LOW);
  timer.deleteTimer(timer_no);
BLYNK_READ(V8)
 Blynk.virtualWrite(V8, drink_level1);
BLYNK_WRITE(V7)
  interval = param.asInt();
  interval1 = interval * 1000.0;
  pinMode(52, OUTPUT);
  Serial3.begin(115200);
  Blynk.begin(auth, wifi, ssid, pass);                          //Reguler server
  //Blynk.begin(auth, wifi, ssid, pass, "192.168.43.120", 8080);    //Local server
  if ( Serial3.available() )   {
    Serial.write( Serial3.read() );
  if ( Serial.available() )       {
    Serial3.write( Serial.read() );
Well, Blynk.begin is a blocking function, so if you don’t have a connection to either WiFi or the Blynk server then you code won’t progress beyond the Blynk.begin line
Setting-up your own WiFi connection then using Blunk.config and Blynk.connect will fix that one. A search of the forum will reveal some examples, although life is more difficult when you use the Arduino/ESP-01 combo.
Then, I’d get rid of all the BLYNK_READ(V8) stuff and simply maintain a count of the water level within your code and upload it to Blynk if you can.
It would also make sense to write the value to non-volatile memory so that it persists if power is lost, but with the Arduino the only option there is EEPROM which has a read-write life of around 100,000 operations, so isn’t a great idea.
If you were using an ESP8266 NodeMCU device then you could use SPIFFS, or the new FS, and if you were using an ESP32 then you could also use RTC memory.
Thank you Pete
Thank you Pete, now it works
int drink_level;
BLYNK_CONNECTED()
Blynk.syncVirtual(V6);
BLYNK_WRITE(V6)
drink_level = param.asInt();
BLYNK_WRITE(V5) //Button to refill
   int refill = param.asInt();
   if (refill == 1)
   drink_level = drink_level + 50000.0;
   Blynk.virtualWrite(V6, drink_level); //V6 is level widget
BLYNK_WRITE(V1) //Button to activate pump
int confirmPressed = param.asInt();
if (confirmPressed == 1)
pump_on();
void pump_on()
digitalWrite(1, HIGH)
int pumpTime = 5000;
timer.getTimeout(pumpTime, []()
digitalWrite(1, LOW)
drink_level = drink_level - pumpTime;
Blynk.config(auth);
Blynk.connectWiFi(ssid, pass);
Blynk.connect();
pinMode(1, OUTPUT);
