I’m working on an HVAC control using an ESP8266. The controls work great from my iPhone but I am setting up a Raspberry Pi and would like to be able to control my Blynk widgets from this device instead of using a mobile device. Ideally the Pi will be mounted on the wall to replace my existing HVAC control.
How can I use Blynk widgets on a non iOS or Android device? Can this be done?
Thanks,
Bruster
Why dont you simply use Blynk android app with Raspberry PI? You just need to install blynk library from Github into Raspberry PI and will be able to control any Raspberry Pi Gpio using Android app.
After installing the Blynk library, just run the command and Blynk will be ready to use
sudo ./blynk --token= YourAuthToken
Of course python code is needed to control every thing, here is one blynk raspberry pi example to control a gpio connected AC appliance from blynk app on android phone
By doing this you can integrate it in your HVAC system.
