Can I put code inside "while (Blynk.connect() == false) {"?
I have a wireless light switch that I would like to automatically turn off if my arduino disconnects from Blynk… Can I do something like…
digitalWrite(1, LOW);
I’d rather put an IF statement in there, not sure why, but it sounds more logical to me. I think it should work, have you tried?
I think we have something like
BLYNK_DISCONNECTED
@vshymanskyy is that working?
Instead of if (Blynk.connect()==…), I would use (if Blynk.connected)
 * Connects to the server.
 * Blocks until connected or timeout happens.
 * May take less or more then timeout value.
 * @param timeout    Connection timeout
 * @returns          True if connected to the server
bool connect(unsigned long timeout = BLYNK_TIMEOUT_MS*3);
bool connected();
As mentioned before Blynk.connected() is your only option since you don’t want to connect to blink cloud again.
No, this feature is postponed for later release (multiple implementations possible).
