Can i connect jy-21 to arduino and blynk to report sales
Hello everyone
just a question. it is possible to connect a JY-21 card with an Ardiuno by means of the counter output, the idea is to be able to monitor the amounts of coins or credits that are entered in the insert coin
I leave the link and manual that you can download from the JY-21 board
http://juyao66.com/1-kit-of-jy-928jy-21-coin-acceptor-with-timer-board-coin-operated-time-control-device-for-cafe-kiosk-for-1- 8-kinds-of-coins_p0031.html
I already have the board jy21 and the arduino, I also need to know if all this works through a SIM800L, IOS SYSTEM IOS, MAC.
thank you very much for your comments
if someone wants to participate in the process together with me is welcome
Greetings César MOLINA
cesarmr80@gmail.com
Hola a todos
solo una pregunta. es posible conectar una tarjeta JY-21 con un Ardiuno por medio de la salida del contador, la idea es poder monitorear las cantidades de monedas o créditos que se ingresan en el insert coin
dejo el enlace y manual que pueden descargar de la placa JY-21
http://juyao66.com/1-kit-of-jy-928jy-21-coin-acceptor-with-timer-board-coin-operated-time-control-device-for-cafe-kiosk-for-1-8-kinds-of-coins_p0031.html
ya tengo la placa jy21 y el arduino, ademas necesito que saber si todo esto funciona por medio de una SIM800L, OCUPO SISTEMA IOS, MAC.
muchisimas gracias por sus comentarios
si alguien quiere participar en el proceso junto con migo esta bienvenido
Saludos César MOLINA
cesarmr80@gmail.com
