I have a ds18b20 temp sensor running on v1 and that works fine.I tried adding the eventor to v1 in order to trigger a temperature notification if the value goes too high. above 20 C. i have installed the notification widget aswell. but nothing happens when the temp goes over 20C. i will upload the sketch mayby the problem is in there somewhere. any help will be greatly appreciated.
#include <OneWire.h>
#define ONE_WIRE_BUS 2 // This is the ESP8266 pin
DeviceAddress tempSensor1 = {0x28,0xFF,0x52,0x0E,0xA1,0x16,0x03,0xB2 }; // Temperature probe #1
DeviceAddress tempSensor2 = {0x28,0xFF,0xD2,0x04,0xA1,0x16,0x05,0xBF}; // Temperature probe #2
char auth[] = “xxxxxxxx”;
char ssid[] = “xxxxxx”;
char pass[] = “xxxxxx”;
int temperature1, temperature2; // Variables for storing temperatures
// Wait until connected
sensors.begin();
sensors.setResolution(tempSensor1, 10); // More on resolutions: http://www.homautomation.org/2015/11/17/ds18b20-how-to-change-resolution-9101112-bits/
sensors.setResolution(tempSensor2, 10);
// These timers are used to keep the loop() nice and leak… keeps Blynk from getting flooded.
timer.setInterval(100L, sendSensor1);
timer.setInterval(150L, sendSensor2);
void sendSensor1() {
sensors.requestTemperatures(); // Polls the sensors
temperature1 = sensors.getTempC(tempSensor1); // Stores temp in F. Change getTempF to getTempC for celcius.
Blynk.virtualWrite(1, temperature1); // Send temp to Blynk virtual pin 1
void sendSensor2() {
temperature2 = sensors.getTempC(tempSensor2);
Blynk.virtualWrite(2, temperature2);
