Like optional textinput at terminal widget… It would be very helpful to have a button to empty it without need to stop/start etc…
And of course, to reimplement (?) terminal.clear() will be appreciated
//===== Clear Terminal Widget =====
BLYNK_WRITE(vPin) { // Button Widget
if (param.asInt()) {
Blynk.virtualWrite(vPin, "clr"); // Clears terminal if button state is 1
I see… I find this works just as well… except for the terminals tendency to sometimes double up text Usually only on the first line, which never shows until the 2nd line is input… then it doubles… but another topic I guess
Just showing my alternative data entry and clear button solution.
BTW, I thought this issue was cleared up?? Along with the duplicate text issue… perhaps they can add in your CLR button when fixing those
Perfect as alternative… but having terminal acting as a log… without entry input… a solution like i posted is more clean, do you think?
Not knocking your idea, it would probably be a good optional addon, I guess… from some perspective… as some may NOT want a terminal to be clearable by the user.
I still like the fact that Blynk is a customisable development environment as many “built in” feature requests are not always as popular with some as others.
as an option like the input text… it will work, i think.
