No. Only 1 command is send on press and 1 command on release.
But he is using it as push type n not as switch. So it will be flooding right ?
No. The only difference is that the switch button changes the state right away. While with the push button state is preserved until you release the button.
I had misunderstood this the whole time. Sorry for the wrong information.
The button widget in PUSH mode sends a 1 when pressed, and a zero when released
In SWITCH mode it sends a 1 when it goes from off to on, and a 0 when it goes from on to off.
There is no constant stream of 1ās when it is pressed in PUSH mode, so no server flooding.
@timgtech Iāve just flashed this code onto a NodeMCUā¦
#define BLYNK_TEMPLATE_ID "REDACTED"
#define BLYNK_DEVICE_NAME "REDACTED"
char auth[] = "REDACTED";
char ssid[] = "REDACTED";
char pass[] = "REDACTED";
Serial.begin(74880);
pinMode(2,OUTPUT); // NodeMCU built-in LED, Active LOW
digitalWrite(2,HIGH); // Turn the LED off
BLYNK_WRITE(V0)
Serial.println(param.asInt());
if(param.asInt() == 1)
// execute this code if the switch widget is now ON
digitalWrite(2,LOW); // Set digital pin LOW
// execute this code if the switch widget is now OFF
digitalWrite(2,HIGH); // Set digital pin HIGH
The onboard LED stays On for as long as the button widget attached to V0 is pressed. This is what the serial output looks like:
09:39:35.898 -> 1
09:40:06.307 -> 0
09:40:12.881 -> 1
09:41:10.980 -> 0
09:44:53.952 -> 1
09:46:12.927 -> 0
As you can see, you can keep the button widget pressed for as long as you wish, and the Off (0) command is received when the button widget is released.
Iād guess that thereās an issue with the board or the relay (possible power issues?) or the WiFi connection, but there is no change in behaviour of the button widget between Blynk Legacy and Blynk 2.0.
Just tested it also, i can confirm that the pushbutton works as it should be. So itās not a Blynk problem.
This is really bizarre! I really do appreciate everyoneās help and input. Using the same board, with the same relay, and the same power supply, and the same code that I have always used with the old Blynk it behaves this way with the new Blynk. I went back to the old Blink and it works just fine. This really is not a big problem or a deal breaker in the grand scheme of things. Just very very strange.
For now when, I move it back to the new Blynk I will just use the Switch instead of momentary button. This is probably the one and only project that I will need to do this with.
Thanks again everyone.
Just out of curiosity, how long are you able to hold the button down and it stay on? (whatever you are turning on).
The longest I tested was 1 minute 15 secondsā¦
I couldnāt be bothered to do any longer, especially as you said they 10 seconds was the longest you could achieve.
I tested it for about 40 seconds
maybe its his phoneā¦
I had this problem on both Android and iOS and different MCU boards. For whatever strange reason now the problem mysteriously just went away it seems. Thanks everyone for the help and suggestions. We can call this one closed.
