Button Logic
Hi There!
I believe you also need incorporate the button (push/switch) logic from HIGH to LOW as well. Right now only LOW to HIGH is available, this will prevent to use the active low relay modules directly. Is this something can be expected in the near future?
you can use Virtual Pins for that with a simple IF statement
Agreed! But having this feature makes the product more user friendly for beginners.
It’s supposed to be implemented someday:
