Sir,
I have tried Blynk in Arduino uno with ethernet shield using blynk ethernet librery, I created 4 relay control, it is working but some time multiple relay is on or off while pressing a single button.
Hi, welcome to blynk, post your code, are you using a relay shield or custom relay board?
Sir,
I used ethernet librery sample code with auth and ip changed,and relay module not shield but relay board is functioning well with other code.
#include <Ethernet.h>
char auth[] = “YourAuthToken”;
Blynk.begin(auth);
// You can also specify server.
// For more options, see BoardsAndShields/Arduino_Ethernet_Manual example
//Blynk.begin(auth, “server.org”, 8442);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8888);
hey, maybe there’s something wrong with the wiring?
does it work without Blynk?
Yes, I was using the same relay module with different arduino android software.
