Bug in the tabs or history graph
I’ve found a bug in tabs or history graph. When i start the project while being on the second or third tab and then stop it while being on the same tab. Then when i tap on an empty space to add a widget, the setting of the history graph pops up that corresponds to the graph that i have on the first tab. It only seems to happen with the history graph.
Hello. Thank you for reporting. This bug had been fixed already. Fix will be available in next update. Sorry for inconveniences.
