Bridge Widget Not Working
I’m trying to send a value from one Arduino Uno board to another Arduino Uno board which both are connected to Blynk server via USB. But I can’t make it work, even for simple digital pin value. Here is the code that I use:
Sender - Uno A:
[code]
SoftwareSerial DebugSerial(2, 3);
char auth[] = “42d9928a261b4d008ed8c35d3068b7d9”;
WidgetBridge bridge1(V1);
static bool value = true;
int ledPinA = 10;
int ledPinB = 12;
void blynkAnotherDevice(){
if(value){
digitalWrite(ledPinA, HIGH);
bridge1.digitalWrite(ledPinB, HIGH);
else{
digitalWrite(ledPinA, LOW);
bridge1.digitalWrite(ledPinB, LOW);
value = !value;
void setup(){
DebugSerial.begin(9600);
Blynk.begin(auth, Serial);
while(!Blynk.connect());
bridge1.setAuthToken(“779e3447c4914b6986852a31d65161d6”);
timer.setInterval(1000L, blynkAnotherDevice);
void loop(){
}[/code]
Receiver - Uno B:
char auth[] = "779e3447c4914b6986852a31d65161d6";
void setup(){
  pinMode(13,OUTPUT);
  pinMode(12,OUTPUT);
void loop(){
Is there anything wrong about the code?
Hello. Please try to follow our bridge example : https://github.com/blynkkk/blynk-library/blob/master/examples/Widgets/Bridge/Bridge.ino
I did. I made a little modification from the example that you give due to my hardware limitation.
I suspect there is a different method to do bridge.setAuthToken() if we connect the board to the internet via USB? Just like when we do Blynk.begin()?
See the USB_Serial example. It contains a sketch, but it’s basically the same yes.
I tried it before I was doing all this. I managed to blink LED using Blynk app with the board connected to internet via USB.
What do you think about my code above? Is there anything you found suspicious to be the problem?
No, your code looks fine from here. Using the timer’s is the way go and loop() is clean, keep that up :slight_smile:
But, still, it’s not working. Uno B’s Pin D12 stays LOW eventhough Uno A asked it to be HIGH.
On UNO A, try to add the function:
BLYNK_CONNECTED()
  bridge1.setAuthToken("779e3447c4914b6986852a31d65161d6");
Above setup is fine, just like you would use BLYNK_WRITE, outside of any function(s).
Have done that. It’s still not working :disappointed:
God. This problem drives me crazy. I don’t know what’s wrong with it.
Don’t see anything strange. Please try to use virtual pins instead of digital. Does that work?
Just saw. YOu have different pin indexes in sketch 1 and sketch 2. IS that correct?
I did try using virtual pin, same thing happened.
I’m sorry, I’m kind of lost. What do you mean by pin indexes?
Please post your code.
int ledPinA = 10;
int ledPinB = 12;
and
pinMode(13,OUTPUT);
pinMode(12,OUTPUT);
Also please post here debug output.
Uno A’s ledPinA is connected to a LED. I made it that way so I can see in what state a LED connected to Uno B’s D12 should be. I set Uno B’s D13 as OUTPUT so that I can switch it up/down using button widget at the app, I did this to make sure that my board is accessible from the internet. So the only Uno B’s pin that I want to remotely switch from Uno A is D12.
I can’t open Serial Monitor because the COM port is busy, used to connect the board to the internet.
BRB.
Here is the code.
Sender - Uno A:
#define MY_VP 5 // debugging purpose
#define PLEASE_REMOTE_THIS_VP 27
char auth[] = "4814623d761e4446b708bxxxxxxxxxxx";
void setup(){
void loop(){
BLYNK_CONNECTED() {
  bridge1.setAuthToken("fbfdc905b5694bff90c32xxxxxxxxxxx");
  if(value){
    Blynk.virtualWrite(MY_VP, 1); // debugging purpose
    bridge1.virtualWrite(PLEASE_REMOTE_THIS_VP, 1);
  else{
    Blynk.virtualWrite(MY_VP, 0); // debugging purpose
    bridge1.virtualWrite(PLEASE_REMOTE_THIS_VP, 0);
  value = !value;
Receiver - Uno B:
#define BUTTON_FROM_APP_VP 8 // debugging purpose
#define REMOTE_THIS_VP_STATE 0 // to show PLEASE_REMOTE_THIS_VP's state in app
char auth[] = "fbfdc905b5694bff90c32xxxxxxxxxxx";
void setup(){
void loop(){
BLYNK_WRITE(PLEASE_REMOTE_THIS_VP){
  int pinData0 = param.asInt();
  Blynk.virtualWrite(REMOTE_THIS_VP_STATE, pinData0); // show bridged VP's state in app
BLYNK_WRITE(BUTTON_FROM_APP_VP){ // debugging purpose
  int pinData1 = param.asInt();
  digitalWrite(13, pinData1);
I’m kind of sceptic about BLYNK_WRITE(PLEASE_REMOTE_THIS_VP) being executed.
@vshymanskyy A little help, maybe?
Does this problem happen simply because I’m using USB cable and not Ethernet/WiFi shield?
@imsyf code seems fine to me. Are you sure your boards are online? How do you verify this?
I use button widget from the app to toggle D13 in both of them, and it works.
