Bridge widget data load
hi, how much data values can bridge support with bridge1.virtualWrite(V5, value1,value2,…valueX)?
thanks
As far as I know, it is will be the same as a normal Blynk.virtualWrite() so basically, give it a test and see.
http://docs.blynk.cc/#blynk-firmware-virtual-pins-control-blynkvirtualwritevpin-value
Since it sends all the commands at once, you might need to keep within the normal recommended 10 writes per second, hardware depending (i.e UNO slow, ESP32 faster).
