I have been searching everywhere for good examples in using this widget but can only find one where a relay switch is turned on or off. What i am trying to achieve is a bit different. I have 2 nodeMCU’s, Master & Slave. The idea is for an aquarium led fixture where the master will send a set of values to the Slave where the Slave will take these values and implement them into a led fading code flashed on the Slave.
The approach i have taken is
List item The intensity of the led, the fadeintime and fadeouttime and the time input send values to the Slave.
The Slave is supposed to take these values and implement them into to fade code.
What is happening is…well nothing really, both Master and Slave connect up but there does not seem to be communication between them. I would appreciate any help with this. I have left the auth codes in to show that they are linked correctly.
MASTER CODE
//#define BLYNK_PRINT Serial
#include <WidgetRTC.h>
//#include <FadeLed.h>
WidgetRTC rtc;
//WIFI Variables
char auth[] = "79498609bb2e47ae95248239105346b4"; //Master auth
char ssid[] = "";
char pass[] = "";
//BRIDGE WIDGET//
WidgetBridge bridge1(V0);
//RTC/Time Input Widget Variables
char currentTime[9];
char currentDate[11];
char startTime[9];
char stopTime[9];
int SThour;
int STmin;
int STsec;
int SPhour;
int SPmin;
int SPsec;
int dayNumber;
bool activeToday = true;
bool scheduler = true;
bool schedulerStatusChange = false;
//LED FADE ATTRIBUTES & VARIABLES
//FadeLed CH1(V10);
int FadeIN = 0;
int FadeOUT = 0;
int maxPWM;
unsigned long FadeInTime;
unsigned long FadeOutTime;
BLYNK_CONNECTED() //Connect to Blynk server
bridge1.setAuthToken("27796ba8ad5c4c649f73c7592ca221f2"); //Slave auth
Blynk.syncAll();
//CH1.set(0);
rtc.begin();
setSyncInterval(30);
timer.setInterval(1000L, ClockDisplay);
timer.setInterval(500L, TimeCheck);
void ClockDisplay()
sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second());
sprintf(currentDate, "%02d/%02d/%04d", day(), month(), year());
Blynk.virtualWrite(V6, currentTime); //Send time to TIME widget
Blynk.virtualWrite(V7, currentDate); //Send date to DATE widget
BLYNK_WRITE(V1) //CH1 TIME IMPUT WIDGET
TimeInputParam t(param);
SThour = t.getStartHour();
STmin = t.getStartMinute();
STsec = t.getStartSecond();
SPhour = t.getStopHour();
SPmin = t.getStopMinute();
SPsec = t.getStopSecond();
dayNumber = weekday();
activeToday = false;
unsigned int OnDays = 0;
for (int i = 1; i <= 7; i++) // Process weekdays (1-Mon, 2-Tues, 3-Wed, 4-Thurs, 5-Fri, 6-Sat, 7-Sun)
if (t.isWeekdaySelected(i))
OnDays++;
if(i==dayNumber)
activeToday = true; //Active today
Serial.println(String("Day ") + i + " is selected");
if (OnDays == 0) //Not active today
BLYNK_WRITE(V2) //CH1 FADEIN TIME WIDGET
FadeIN = param.asInt();
FadeInTime = (FadeIN * 60000); //Fadein param is in minutes as set by widget
bridge1.virtualWrite(V11, FadeInTime); //Send fadein time to Slave
Serial.print("LedFadeIn Time: ");
Serial.println(FadeInTime);
BLYNK_WRITE(V3) //CH1 FADEOUT TIME WIDGET
FadeOUT = param.asInt();
FadeOutTime = (FadeOUT * 60000); //Fadeout param is in minutes as set by widget
bridge1.virtualWrite(V12, FadeOutTime); //Send fadeout time to Slave
Serial.print("LedFadeOut Time: ");
Serial.println(FadeOutTime);
BLYNK_WRITE(V4) //CH1 UV INTENSITY WIDGET
int PWMinput = param.asInt();
maxPWM = map (PWMinput, 0, 100, 0, 1023); //Intensity param set with widget
bridge1.virtualWrite(V13, maxPWM); //Send intensity value to Slave
Serial.print("Intensity: ");
Serial.println(maxPWM);
/*void LedFadeIn ()
CH1.setTime(FadeInTime);
CH1.set(maxPWM);
void LedFadeOut ()
CH1.setTime(FadeOutTime);
CH1.set(0);
void ProgressBar()
CH1.getCurrent();
Serial.print("Progress: ");
Serial.println(CH1.getCurrent());
Blynk.virtualWrite(V5, CH1.getCurrent());
void TimeCheck()
sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second()); //Get RTC time
Serial.print("Current Time: ");
Serial.println(currentTime);
sprintf(startTime, "%02d:%02d:%02d", SThour, STmin, STsec); //Get start time from widget
Serial.print("Start Time: ");
Serial.println(startTime);
sprintf(stopTime, "%02d:%02d:%02d", SPhour, SPmin, SPsec); //Get stop time from widget
Serial.print("Stop Time: ");
Serial.println(stopTime);
if (activeToday == true)
if (hour() == SThour)
if (minute() == STmin)
//LedFadeIn();
bridge1.virtualWrite(V1, 1); //Send a value of 1 to Slave as time to dim up
else if (hour() == SPhour)
if (minute() == SPmin)
//LedFadeOut();
bridge1.virtualWrite(V1, 0); //Send a value of 0 to Slave as time to dim down
SLAVE CODE#include <ESP8266WiFi.h>
WidgetRTC rtc;
char auth[] = "27796ba8ad5c4c649f73c7592ca221f2"; //Slave auth
char ssid[] = "";
char pass[] = "";
//BRIDGE WIDGET//
static bool bridge = true;
FadeLed CH1(D4);
int FadeIN = 0;
int FadeOUT = 0;
int maxPWM;
bridge1.setAuthToken("79498609bb2e47ae95248239105346b4"); //Master auth
Blynk.syncAll();
void SyncChannels()
FadeLed::update();
analogWrite (D4, 0);
CH1.set(0);
timer.setInterval(10L, SyncChannels);
timer.setInterval(500L, ProgressBar);
BLYNK_WRITE(V10) //Function to determine to fade up or fade down
int pinData = param.asInt();
if (pinData == 1) //Value of 1 received from Master = fade up
LedFadeIn();
else if (pinData == 0) //Value of 0 received from Master= Fade down
LedFadeOut();
BLYNK_WRITE(V11)
FadeInTime = param.asInt(); //Fadein time received from Master
BLYNK_WRITE(V12)
FadeOutTime = param.asInt(); //Fadeout time received from Master
BLYNK_WRITE(V13)
maxPWM = param.asInt(); //Intensity value received from Master
void LedFadeIn ()
CH1.set(maxPWM);
void LedFadeOut ()
CH1.set(0);
void ProgressBar()
CH1.getCurrent();
