Bridge sends data faster than timer function limit to database (not app)
Hello everyone,
First things first…
 1. The Blynk library version you are using.                       **(0.5.1)**
 2. Android or iOS and the version of the OS.                      **(Android 5.0)**
 3. Server type, Local or Cloud based.                             **(Local Server)**
 4. If local server, which version you are using.                  **(0.33.1-java8)**
 5. How you powering the MCU.                                      **(with USB)**
 6. Has the MCU ever connected to a Blynk server (Cloud or local). **(yes)**
 7. The IDE you areusing, including the version number.            **(Arduino 1.8.0)**
 8. The settings you have in the IDE for the MCU.                  **(ESP8266-01)**
 9.The Arduino core version you are using.                         **(1.8.0)**
10. The make and model of your phone.                              **(Samsung Note 3)**
I have ESP8266-01 module with DHT22 for temp sens and send them to Nodemcu with bridge. My code as same as Bridge example. I can send data to Nodemcu, Nodemcu receive them and show to me by app for desired periods (5min) . But it happens to fast for my postgresql database, :hushed: exactly 15 sec. But my timer function for this 5min.
#include <DHT.h>
#define DHTPin 2
#define DHTTYPE DHT22
char auth[] = "xxx";
char ssid[] = "xxx";
char sifre[] = "xxx";
float hum;
float temp;
WidgetBridge Bridge1(V5);
DHT dht(DHTPin, DHTTYPE);
BlynkTimer timer1;
BLYNK_WRITE(V5)
  int pin = param.asInt();
  if (pin == HIGH)   sending();
BLYNK_CONNECTED()
  Bridge1.setAuthToken("xxx");
  dht.begin();
  WiFi.begin(ssid, sifre);
  Blynk.config(auth, IPAddress(xxx, xxx, xxx, xxx), 8080);
  Blynk.virtualWrite(V0, BLYNK_VERSION);
  Blynk.virtualWrite(V1, ESP.getCoreVersion());
  sending();
  timer1.setInterval(300000L, sending);
void sending()
  temp = dht.readTemperature();
  delay(1250);
  hum = dht.readHumidity();
  if (isnan(hum) || isnan(temp))
    Serial.println("DHT error!");
    delay(500);
    return;
  Blynk.virtualWrite(V19, temp);
  delay(1250);                      // This delays for the emoncms.org webhooks
  Blynk.virtualWrite(V20, hum);
  Bridge1.virtualWrite(V19, temp);
  delay(1250);
  Bridge1.virtualWrite(V20, hum);
  timer1.run();
As you see this sending function must work for 5 min periods but it sends to data my database for 15 sec periods.
Ekran Alıntısı2
  1. Is that normal for database?
  2. What must I do? thanks…
SOLVED…
if both device have same pins (like on nodemcu V2 and V2 on ESP8266) postgresql store them same pin number BUT different device_id :slight_smile:
add device_id=(xxxx) to my query and bingo…
