Bridge - Device available?
Using the bridge functionality, what happens if the other device is offline? How can I check that it’s online before communicating?
I suppose that I can make a simple “keep-alive” mechanism between the 2 devices, but I was wondering if something already exists natively.
Or maybe there’s a way to tell if a command has been sent successfully or not?
Thank you.
The command always gets sent to the server… if the receiving device is offline at the time, then I guess you could try Blynk.syncVirtual(vPin) when it reconnects.
http://docs.blynk.cc/#blynk-firmware-virtual-pins-control-blynksyncvirtualvpin
