Hi there
I´m trying to change my code from a Yun board to a wemos d1 mini.
It´s a simple bridge example that performs well using Yun.
But when I compile it using the d1 Board I get this error message:
xtensa-lx106-elf-gcc: error: libraries\Bridge\Bridge.a: No such file or directory
Any idea?
My code:
Detects the status of Garage door by RED switch and
send´s it to:
~ TOR_Receiver which will blink the BUILTIN_LED when door is open
~ Blynk APP Tor_Status Value V11
~ Blynk APP Tor_Status LED
#include <Bridge.h>
#include <MY_WiFi.h> // MY_personal WiFi credentials
#define MY_switch D1
char auth[] = "xxxxxxxx"; //Tor-Status-ESP-D5EFEB
WidgetBridge bridge1(V1); // Bridge widget on virtual pin 1
{ pinMode(BUILTIN_LED, OUTPUT); // initialize onboard LED as output BUILTIN_LED=D4
pinMode(MY_switch, INPUT_PULLUP);
delay (1000);
noInterrupts();
timer0_isr_init();
timer0_attachInterrupt(timer0_ISR);
timer0_write(ESP.getCycleCount() + 80000000L); // 80MHz == 1sec
interrupts();
BLYNK_CONNECTED() {
bridge1.setAuthToken("yyyyyyy"); // Place the AuthToken of the second hardware here Tor-Receiver-ESP-D5F066
if (digitalRead(MY_switch) == HIGH)
Serial.println("HIGH");
bridge1.digitalWrite(4, HIGH); // Digital Pin 9 on the second board will be set HIGH
bridge1.virtualWrite(V5, 1); // Sends 1 value to BLYNK_WRITE(V5) handler on receiving side.
Serial.println(F("write HIGH"));
Serial.println("LOW");
bridge1.digitalWrite(4, LOW); // Digital Pin 9 on the second board will be set LOW
bridge1.virtualWrite(V5, 0); // Sends 0 value to BLYNK_WRITE(V5) handler on receiving side.
Serial.println(F("write LOW"));
BLYNK_WRITE(V5) { //This is only for example to demonstrate the board is still running
int pinData = (param.asInt() * 255); // pinData variable
digitalWrite(BUILTIN_LED, pinData);
void timer0_ISR (void) //this is for example only change it to your ISR needs
digitalWrite( BUILTIN_LED, digitalRead( BUILTIN_LED ) ^ 1 ); // blink 1/sec
May be I found it my self.
the include bridge.h is not present within the actual example of bridge
I deleted it in my sketch and could compile with out error message.
I hope that it will now work without the include ???
I do not remember where it is from.
I used the blynk examples to perform my first steps together with Yun and blynk.
@vshymanskyy
Sorry but I have to correct you.
But it is provided together with blynk.
When I load the < example < blynk < boards_wifi < Arduino_yun
It will load the sketch like below
and bridge.h is included.
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* This example shows how to use Arduino Yun Bridge
* to connect your project to Blynk.
* Feel free to apply it to any other example. It's simple!
**#include <Bridge.h>**
#include <BlynkSimpleYun.h>
@Costas,
thank you for your clarification. @vshymanskyy
sorry for my mistake, because it has been provided together with the yun blynk example I assumed that it uses to blynk.
