Arduino Nano (old bootloader) with ESP8266 (AT version:0.51.0.0(Nov 27 2015 13:37:21) SDK version:1.5.0, compile time:Nov 27 2015 13:57:56
and AT version:1.3.0.0(Jul 14 2016 18:54:01) SDK version:2.0.0(5a875ba) Farylink Technology Co., Ltd. v1.0.0.2 May 11 2017 22:23:58
) as a shield via softwareSerial.
AVR boards 1.16.21. Blynk 0.6.0. and 0.6.1.
Blynk library version 0.6.X. seems to break BME280 sensor in some way. If there are any virtualWrites and BME280 sensor is initialized, the program hangs after [9521] Connected to WiFi [19868] Ready (ping: 25ms).
being unable to connect to Blynk servers. When commenting out the virtualWrites, the program works. I’m not sure why. It works fine on 0.5.4.
It seems that it hangs on while(this->connect() != true) {}
in Arduino\libraries\Blynk\src\BlynkSimpleShieldEsp8266.h
Topic with disscussion: VirtualWrite crashes the execution of sketch
Example code that doesn’t work.
#include <ESP8266_Lib.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define DEBUGMODE 1
#define SERIALDATRATE 9600
#define ESP8266_BAUD 9600
Adafruit_BME280 bmeInside;
ESP8266 wifi(&EspSerial);
char auth[] = "";
char ssid[] = "";
char pass[] = "";
/* blynk pinout
* LCD0 - V5,
typedef const uint8_t pin;
struct blynkPins {
pin LCD0 = V5;
} pinBlynk;
// how often to update the data in ms
struct updateRateStruct {
const uint16_t sensor = 1 * 1000;
const uint16_t blynk = 1 * 60000;
} updateRate;
struct sensorData {
float inTemperature;
float inHumidity;
float inPressure;
} sensor;
WidgetLCD lcd0(pinBlynk.LCD0);
void sendBlynk(void);
void updateSensors(void);
void pollBmeInside(void);
uint32_t currentMillis = 0;
#if DEBUGMODE
Serial.begin(SERIALDATRATE);
Serial.println("Starting in debug mode");
Serial.println("----------------------------\n");
#endif
bmeInside.begin(0x76);
currentMillis = millis();
updateSensors();
sendBlynk();
void updateSensors(){
static uint32_t previousMillis = 0;
if ((currentMillis - previousMillis) >= updateRate.sensor){
pollBmeInside();
void pollBmeInside(){
sensor.inHumidity = bmeInside.readHumidity();
sensor.inTemperature = bmeInside.readTemperature();
sensor.inPressure = bmeInside.readPressure() / 100.0F;
#if DEBUGMODE
Serial.println("bmeInside data:");
Serial.println("t °C:\th %:\tp hPa:");
Serial.print(sensor.inTemperature);
Serial.print("\t");
Serial.print(sensor.inHumidity);
Serial.print("\t");
Serial.println(sensor.inPressure);
#endif
void sendBlynk(){
if ((currentMillis - previousMillis) >= updateRate.blynk){
lcd0.clear();
lcd0.print(0, 0, "T: ");
lcd0.print(3, 0, sensor.inTemperature);
lcd0.print(9, 0, "H:");
lcd0.print(11, 0, sensor.inHumidity);
lcd0.print(0, 1, "Pres:");
lcd0.print(7, 1, sensor.inPressure);
#if DEBUGMODE
Serial.println("blynk trig\n");
#endif
