'BlynkTimer' does not name a type... SOLVED!
’BlynkTimer’ does not name a type , this took me a little bit to solved it. I am posting it here just in case somebody else is having this “issue.” I solved by creating a new Application(by the way, I am using the Web Particle IDE, so the code is for the Particle Photon IoT ), paste exactly the same code, add required libraries, bingo! It compiled with not issues. I will attribute this problem to the Particle IDE rather than Blynk itself. Yes, I clear the cache, that did not help.
