'BlynkStream::begin(char [33])' error
here is the code
#include <NewPing.h>
 Social networks:            http://www.fb.com/blynkapp
                             http://twitter.com/blynk_app
This example shows how to use ordinary Arduino Serial
to connect your project to Blynk.
Feel free to apply it to any other example. It’s simple!
          USB HOWTO: http://tiny.cc/BlynkUSB
//distance measuring printed to blynk lcd screen
//blynk over usb definitions
SoftwareSerial SwSerial(2, 3); // RX, TX
#define BLYNK_PRINT SwSerial
//#define BLYNK_PRINT DebugSerial
//#include “blynk/blynk.h”
//newping library definitions
#define TRIGGER_PIN 4 // trigger pin on the ultrasonic sensor.
#define ECHO_PIN 2 // echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance in centimeter.
char auth[] = “adfbdd263fa149f5ab76d2c58260335e”;
WidgetLCD lcd(V1);
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
//variables used in smothing the values from distance sensor
const int numReadings = 50; //number of readings
String distance; //make average to string later
int readings[numReadings]; // the readings from the analog input
int readIndex = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; //the average value
//void setup()
//DebugSerial.begin(9600);
//SwSerial.begin(9600);
//Blynk.begin(auth);
Blynk.begin(auth);
// initialize all the readings to 0:
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
// Wait until connected
void code{ //smoothing values from distance sensor
// subtract the last reading:
total = total - readings[readIndex];
// read from the sensor:
readings[readIndex] = sonar.ping_cm();
// add the reading to the total:
total = total + readings[readIndex];
// advance to the next position in the array:
readIndex = readIndex + 1;
// if we’re at the end of the array…
if (readIndex >= numReadings) {
// …wrap around to the beginning:
readIndex = 0;
// calculate the average:
average = total / numReadings;
// send it to the computer as ASCII digits
distance = average; // convert to string
//print to lcd
lcd.clear(); //Use it to clear the LCD Widget
lcd.print(4, 0, distance); //print the average distance
lcd.print(4, 1, “cm”);
delay(30);
code()
and this the error
Continuing the discussion from Simple code error compiling:
Arduino: 1.6.12 (Windows 10), Board: “Arduino/Genuino Uno”
F:\aa\Arduino_Serial_USB_connect_test\Arduino_Serial_USB_connect_test.ino: In function ‘void setup()’:
Arduino_Serial_USB_connect_test:70: error: no matching function for call to ‘BlynkStream::begin(char [33])’
Blynk.begin(auth);
F:\aa\Arduino_Serial_USB_connect_test\Arduino_Serial_USB_connect_test.ino:70:19: note: candidate is:
In file included from C:\Users\varuramaprasad\Documents\Arduino\libraries\blynk-library-0.3.10\src/BlynkSimpleStream.h:18:0,
             from F:\aa\Arduino_Serial_USB_connect_test\Arduino_Serial_USB_connect_test.ino:34:
C:\Users\varuramaprasad\Documents\Arduino\libraries\blynk-library-0.3.10\src/Adapters/BlynkSerial.h:73:10: note: void BlynkStream::begin(const char*, Stream&)
 void begin(const char* auth, Stream& stream) {
C:\Users\varuramaprasad\Documents\Arduino\libraries\blynk-library-0.3.10\src/Adapters/BlynkSerial.h:73:10: note: candidate expects 2 arguments, 1 provided
F:\aa\Arduino_Serial_USB_connect_test\Arduino_Serial_USB_connect_test.ino: At global scope:
Arduino_Serial_USB_connect_test:83: error: expected unqualified-id before ‘for’
Arduino_Serial_USB_connect_test:83: error: ‘thisReading’ does not name a type
Arduino_Serial_USB_connect_test:86: error: expected declaration before ‘}’ token
Multiple libraries were found for “NewPing.h”
Used: C:\Users\varuramaprasad\Documents\Arduino\libraries\NewPing
Not used: C:\Program Files (x86)\Arduino\libraries\NewPing
Multiple libraries were found for “BlynkSimpleStream.h”
Used: C:\Users\varuramaprasad\Documents\Arduino\libraries\blynk-library-0.3.10
Not used: C:\Program Files (x86)\Arduino\libraries\Blynk
exit status 1
“Show verbose output during compilation”
Fix your libraries. Remove all old libraries from Blynk and manually install the latest one. DO NOT USE THE ARDUINO LIBRARY MANAGER!!!
Code snippets should be formatted. Please edit your initial post:
How to do that:
 ``` cpp <--put 3 backticks BEFORE your code starts  ("cpp" means C++ language)
   //Put your code here
 ``` <--insert 3 backticks AFTER your code
**This makes your code readable and with highlighted syntax, like this
//comment goes here
void helloWorld() {
   String message =  "hello" + "world";
