BlynkSimpleUIPEthernet with Codebender
Hi All,
I try to upload this code in an Arduino Nano with an ENC28J60 via Codebender
>  * Blynk is a platform with iOS and Android apps to control
>  * Arduino, Raspberry Pi and the likes over the Internet.
>  * You can easily build graphic interfaces for all your
>  * projects by simply dragging and dropping widgets.
>  *   Downloads, docs, tutorials: http://www.blynk.cc
>  *   Blynk community:            http://community.blynk.cc
>  *   Social groups:              http://www.fb.com/blynkapp
>  *                               http://twitter.com/blynk_app
>  * Blynk library is licensed under MIT license
>  * This example code is in public domain.
>  * This example shows how to use ENC28J60 (UIPEthernet library)
>  * to connect your project to Blynk.
>  * For this example you need UIPEthernet library:
>  *   https://github.com/ntruchsess/arduino_uip
>  * Feel free to apply it to any other example. It's simple!
> #define BLYNK_PRINT Serial    // Comment this out to disable prints and save space
> #include "UIPEthernet.h"
> #include "BlynkSimpleUIPEthernet.h"
> // You should get Auth Token in the Blynk App.
> // Go to the Project Settings (nut icon).
> char auth[] = "cbc274078xxxxxxxxxxxxx94abc2f10f";
> void setup()
>   Serial.begin(9600);
>   Blynk.begin(auth);
>   // You can also specify server.
>   // For more options, see Transports/Advanced/CustomEthernet example
>   //Blynk.begin(auth, "server.org", 8442);
>   //Blynk.begin(auth, IPAddress(192,168,1,100), 8888);
> void loop()
>   Blynk.run();
The verification fail with these error:
ENC28J60.ino:29:10: fatal error: ‘BlynkSimpleUIPEthernet.h’ file not found
Although the specified file is present in my codebender personal library…
Thanks in advance if you have any idea !
Try making it work without Codebender. We haven’t updated them with the latest library
Also, it may be actually an issue of CodeBender…
Thanks, it’s ok with the arduino ide…
hey guys, this is Vasilis, the founder of codebender. Let me know what we can do to get this fixed
Vasilis
