NodeMCU Esp8266 with two ds18b20 sending temps to virtual pins on Blynk. The system goes offline hundreds of times a day but only a day or so after being working.
I have eliminated events that would exceed the limits, the sensor readings are more stable. Would this issue be on my network ? It runs on a dedicated network by itself, provided by an Aruba 570 Series Outdoor Access Point 35 feet away from it.
Only data streams shown below
#define BLYNK_TEMPLATE_ID "TXXXXXX"
#define BLYNK_DEVICE_NAME "Tray Washer"
#define BLYNK_AUTH_TOKEN "XXXXXXXXXXXXXXXX"
char ssid[] = "XXXXXXXXXX";
char pass[] = "XXXXXXXXXX";
//#define BLYNK_PRINT Serial
#include <OneWire.h>
OneWire oneWireA(D6);
OneWire oneWireB(D7);
DallasTemperature sensorsA(&oneWireA);
DallasTemperature sensorsB(&oneWireB);
int lcdColumns = 16;
int lcdRows = 2;
LiquidCrystal_I2C lcd(0x27, lcdColumns, lcdRows);
float temp1, temp2;
lcd.init();
// turn on LCD backlight
lcd.backlight();
pinMode(D5, INPUT); // this is the pin that reads if machine is running.
sensorsA.begin();
sensorsB.begin();
timer.setInterval(600000L, sendTemps);
timer.setInterval(30000L, sendalert);
timer.setInterval(30000L, state);
void sendTemps() {
sensorsA.requestTemperatures();
sensorsB.requestTemperatures();
temp1 = sensorsA.getTempFByIndex(0);
temp2 = sensorsB.getTempFByIndex(0);
Serial.println(temp1);
Serial.println(temp2);
Blynk.virtualWrite(V1, temp1);
Blynk.virtualWrite(V2, temp2);
lcd.setCursor(0, 0);
lcd.print("Dirty ");
lcd.print(temp1);
lcd.print((char)223);
lcd.print("F");
lcd.setCursor(0, 1);
lcd.print("Clean ");
lcd.print(temp2);
lcd.print("F");
void sendalert() {
if (digitalRead(D0) == HIGH && temp1 < 120) {
Blynk.logEvent("low_temp", String("Water Temperature Under Threshold Tº: ") + temp1);
Serial.println("alarm");
void state()
if (digitalRead(D5) == HIGH)
Blynk.virtualWrite(V0, HIGH); // this keeps track of when the machine is running
else if (digitalRead(D5) == LOW) {
Blynk.virtualWrite(V0, LOW);
