BLYNK
BlynkEthernet Manager for STM32 with Built-in LAN8742A Ethernet, W5X00 or ENC28J60 shields
New Releases v1.0.0
  1. Add support to STM32 boards with built-in Ethernet, ENC28J60 or W5x00 Ethernet shields
  • This is the new library, adding to the current Blynk_WiFiManager. It’s designed to help you eliminate hardcoding your Blynk credentials in STM32 boards using with Ethernet (Built-in, W5100, W5200, W5500, ENC28J60, etc). It’s currently not supporting SSL and can not saved config dada to non-volatile memory (EEPROM, battery-saved SRAM, SPIFFS, etc.). To be fixed in future releases.
  • You can update Blynk Credentials any time you need to change via Configure Portal. Data to be saved in configurable locations in EEPROM.
This library currently supports
  1. STM32 boards with built-in Ethernet such as :
  1. STM32 boards (with 64+K Flash) running ENC28J60 shields
  2. STM32 boards (with 64+K Flash) running W5x00 shields
So, how it works?
If no valid config data are stored in EEPROM, it will switch to Configuration Mode . Connect to access point at the IP address displayed on Terminal or Router’s DHCP server as in the following picture:
After you connected to, for example, 192.168.2.113 , the Browser will display the following picture:
Enter your credentials (Blynk Server and Port). If you prefer static IP, input it (for example 192.168.2.113 ) in the corresponding field. Otherwise, just leave it blank or nothing .
Then click Save . After the board auto-restarted, you will see if it’s connected to your Blynk server successfully as in the following picture:
Sample Code
#if defined(ESP8266) || defined(ESP32)
#error This code is designed to run on Arduino AVR, SAM, SAMD, Teensy platform, not ESP8266 nor ESP32! Please check your Tools->Board setting.
#endif
#if defined(ARDUINO_ARCH_STM32F1)
  #define DEVICE_NAME  "STM32F1"
  #define BLYNK_NO_YIELD
#elif defined(ARDUINO_ARCH_STM32F3)
  #define DEVICE_NAME  "STM32F3"
#elif defined(ARDUINO_ARCH_STM32F4)
  #define DEVICE_NAME  "STM32F4"
#elif defined(ARDUINO_ARCH_STM32F7)
  #define DEVICE_NAME  "STM32F7"
#else
  #define DEVICE_NAME  "STM32 Unknown"
#endif
#define USE_BUILTIN_ETHERNET    false
//  If don't use USE_BUILTIN_ETHERNET, and USE_UIP_ETHERNET => use W5x00 with Ethernet library
#define USE_UIP_ETHERNET        false
#if (USE_BUILTIN_ETHERNET)
  #define ETHERNET_NAME     "Built-in STM32 Ethernet"
#elif (USE_UIP_ETHERNET)
  #define ETHERNET_NAME     "ENC28J60 Ethernet Shield"
#else
  #define ETHERNET_NAME     "W5x00 Ethernet Shield"
#endif
// Start location in EEPROM to store config data. Default 0.
// Config data Size currently is 128 bytes w/o chksum, 132 with chksum)
#define EEPROM_START     0
#define USE_SSL     false
#define USE_CHECKSUM      true
#if USE_SSL
  // Need ArduinoECCX08 and ArduinoBearSSL libraries
  // Currently, error not enough memory for many STM32 boards. Don't use
  #error SSL not support
#else
  #if USE_BUILTIN_ETHERNET
    #include <BlynkSTM32BIEthernet_WM.h>
  #elif USE_UIP_ETHERNET
    #include <BlynkSTM32UIPEthernet_WM.h>
  #else
    #include <BlynkSTM32Ethernet_WM.h>
  #endif
#endif
#define USE_BLYNK_WM      true
#if !USE_BLYNK_WM
  #define USE_LOCAL_SERVER      true
  #if USE_LOCAL_SERVER
    char auth[] = "******";
    char server[] = "account.duckdns.org";
    //char server[] = "192.168.2.112";
  #else
    char server[] = "blynk-cloud.com";
  #endif
  #define BLYNK_HARDWARE_PORT       8080
#endif
#if !(USE_BUILTIN_ETHERNET || USE_UIP_ETHERNET)
  #define W5100_CS  10
  #define SDCARD_CS 4
#endif
  Serial.println("\nStart W5100_Blynk on STM32 running " + String(ETHERNET_NAME) + " " + String(DEVICE_NAME));
  pinMode(SDCARD_CS, OUTPUT);
  digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
#endif
#if USE_BLYNK_WM
  Blynk.begin();
#else
    Blynk.begin(auth, server, BLYNK_HARDWARE_PORT);
  #else
    Blynk.begin(auth);
    //Blynk.begin(auth, server, BLYNK_HARDWARE_PORT);
  #endif
#endif
  if (Blynk.connected())
    #if USE_BLYNK_WM
    Serial.print(F("Conn2Blynk: server = "));
    Serial.print(Blynk.getServerName());
    Serial.print(F(", port = "));
    Serial.println(Blynk.getHWPort());
    Serial.print(F("Token = "));
    Serial.println(Blynk.getToken());
    #endif
    Serial.print(F("IP = "));
    Serial.println(Ethernet.localIP());
void heartBeatPrint(void)
  static int num = 1;
    Serial.print(F("B"));
    Serial.print(F("F"));
  if (num == 80)
    Serial.println();
    num = 1;
  else if (num++ % 10 == 0)
    Serial.print(F(" "));
void check_status()
  static unsigned long checkstatus_timeout = 0;
#define STATUS_CHECK_INTERVAL     60000L
  // Send status report every STATUS_REPORT_INTERVAL (60) seconds: we don't need to send updates frequently if there is no status change.
  if ((millis() > checkstatus_timeout) || (checkstatus_timeout == 0))
    heartBeatPrint();
    checkstatus_timeout = millis() + STATUS_CHECK_INTERVAL;
  check_status();
The following is the sample terminal output when running example BI_Ethernet_Blynk on Nucleo-144 F767ZI with built-in Ethernet PHY.
Start BI_Ethernet_Blynk on STM32 running Built-in STM32 Ethernet STM32 Unknown
[1] EEPROM, sz:16384
[3] CCksum=0x0,RCksum=0x0
[6] InitEEPROM
[6621] GetIP:
[6621] IP:192.168.2.94
[6621] bg: No cfgdat. Stay
[6621] CfgIP=192.168.2.94
F[10938] SaveEEPROM,sz=16384,chkSum=0x19b4
[10938] Hdr=W5100,Auth=****
[10941] Svr=account.duckdns.org,Port=8080
[10945] SIP=nothing,BName=STM32-F767ZI-WM
[10949]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.6.1 on Arduino
[10962] BlynkArduinoClient.connect: Connecting to account.duckdns.org:8080
[10984] Ready (ping: 6ms).
[11051] run: got E&B
BBBBBBBBBB BBBBBBBBBB BBBBBBBBBB BBBBBBBBBB BBBBBBBBBB BBBBBBBBBB BBBBBBBBBB BBBBBBBBBB
Updated: Mar 2nd 2020
BlynkEthernet_STM32_WM for STM32 libraries v1.0.0 just got included into Arduino Library Manager.
Now you can install this library directly from Arduino Library Manager
arduino-library-badge
Updated: Mar 3rd 2020
Releases v1.0.1
New in this version
  1. Fix hanging bug in STM32 boards with built-in Ethernet LAN8742A.
Updated: Mar 6th 2020
New in Version v1.0.2
  1. Fix crashing bug when using dynamic EthernetServer
  2. Enhance examples, fix indentation, update README.md
New in Version v1.0.3
  1. Reduce html and code size for faster Config Portal response. Enhance GUI.
  2. Change default macAddress for boards to avoid macAddress conflict while simultaneously testing multiple boards.
Updated April 20th 2020
Releases v1.0.4
  1. New powerful-yet-simple-to-use feature to enable adding dynamic custom parameters from sketch and input using the same Config Portal. Config Portal will be auto-adjusted to match the number of dynamic parameters.
  2. Dynamic custom parameters to be saved automatically in EEPROMe.
  3. Permit to input special chars such as % and # into data fields.
  4. MultiBlynk Servers and Tokens with Auto(Re)Connect feature.
So, how it works?
If no valid config data are stored in EEPROM, it will switch to Configuration Mode. Connect to access point at the IP address displayed on Terminal or Router’s DHCP server as in the following terminal output:
Start BI_Ethernet_Blynk on STM32F7 board, running Built-in LAN8742A Ethernet
[1] EEPROMsz16384
[3] CCSum=0x0,RCSum=0x0
[5] CrCCsum=0,CrRCsum=0
[7] InitEEPROM,sz=16384,Datasz=380
[10] CrCCSum=3120
[12] MAC: FE-C9-A1-8E-D4-B7
[5629] Dynamic IP OK, connected
[6629] IP:192.168.2.88
[6629] bg:NoDat.Stay
F
Your stored Credentials :
MQTT Server = blank
Port = blank
MQTT UserName = blank
MQTT PWD = blank
Subs Topics = blank
Pubs Topics = blank
After you connected to, for example, 192.168.2.86, the Browser will display the following picture:
Enter your credentials (Blynk Server and Port). If you prefer static IP, input it (for example 192.168.2.79) in the corresponding field. Otherwise, just leave it blank or nothing to use auto IP assigned by DHCP server.
Then click Save. After the board auto-restarted, you will see if it’s connected to your Blynk server successfully as in the following terminal output:
[1] EEPROMsz16384
[10] CrCCSum=3120
MQTT Server = blank
Port = blank
MQTT PWD = blank
Subs Topics = blank
Pubs Topics = blank
FFFFFFFFFF FFFFFFFFFF
Save,CSum=0x2c22
[68929] Hdr=LAN8742A,BName=STM32F767ZIT6-Blynk-WM
[68930] Svr=account.duckdns.org,Tok=tokentoken1a1nKgun10heJSu2G6KQUlJRGIOrVD0QX
[68942] Prt=8080,SIP=192.168.2.88
[68945] CrCCSum=8662
[68947]
    ___  __          __
[68961] BlynkArduinoClient.connect: Connecting to account.duckdns.org:8080
[68982] Ready (ping: 7ms).
[69049] Connected to Blynk Server = account.duckdns.org, Token = token
[69052] r:E&B OK
How to add dynamic parameters from sketch
  • To add custom parameters, just modify from the example below
#define USE_DYNAMIC_PARAMETERS     true
/////////////// Start dynamic Credentials ///////////////
//Defined in <BlynkEthernet_STM32_WM.h>
  #define MAX_ID_LEN                5
  #define MAX_DISPLAY_NAME_LEN      16
  typedef struct
  char id             [MAX_ID_LEN + 1];
  char displayName    [MAX_DISPLAY_NAME_LEN + 1];
  char *pdata;
  uint8_t maxlen;
  } MenuItem;
#if USE_DYNAMIC_PARAMETERS
#define MAX_MQTT_SERVER_LEN      34
char MQTT_Server  [MAX_MQTT_SERVER_LEN + 1]   = "";
#define MAX_MQTT_PORT_LEN        6
char MQTT_Port   [MAX_MQTT_PORT_LEN + 1]  = "";
#define MAX_MQTT_USERNAME_LEN      34
char MQTT_UserName  [MAX_MQTT_USERNAME_LEN + 1]   = "";
#define MAX_MQTT_PW_LEN        34
char MQTT_PW   [MAX_MQTT_PW_LEN + 1]  = "";
#define MAX_MQTT_SUBS_TOPIC_LEN      34
char MQTT_SubsTopic  [MAX_MQTT_SUBS_TOPIC_LEN + 1]   = "";
#define MAX_MQTT_PUB_TOPIC_LEN       34
char MQTT_PubTopic   [MAX_MQTT_PUB_TOPIC_LEN + 1]  = "";
MenuItem myMenuItems [] =
  { "mqtt", "MQTT Server",      MQTT_Server,      MAX_MQTT_SERVER_LEN },
  { "mqpt", "Port",             MQTT_Port,        MAX_MQTT_PORT_LEN   },
  { "user", "MQTT UserName",    MQTT_UserName,    MAX_MQTT_USERNAME_LEN },
  { "mqpw", "MQTT PWD",         MQTT_PW,          MAX_MQTT_PW_LEN },
  { "subs", "Subs Topics",      MQTT_SubsTopic,   MAX_MQTT_SUBS_TOPIC_LEN },
  { "pubs", "Pubs Topics",      MQTT_PubTopic,    MAX_MQTT_PUB_TOPIC_LEN },
uint16_t NUM_MENU_ITEMS = sizeof(myMenuItems) / sizeof(MenuItem);  //MenuItemSize;
#else
MenuItem myMenuItems [] = {};
uint16_t NUM_MENU_ITEMS = 0;
#endif
/////// // End dynamic Credentials ///////////
  • If you don’t need to add dynamic parameters, use the following in sketch
#define USE_DYNAMIC_PARAMETERS     false
