ESP8266
BlynkEdgent lib
There is code that works great, but I need to change the WiFi network, where you set the network name and password of the WiFi network in the BlynkEdgent configuration files?
#define BLYNK_TEMPLATE_ID "TMPLxxxxxxxx"
#define BLYNK_DEVICE_NAME "DEVICE NAME"
#define BLYNK_FIRMWARE_VERSION "1.0.1"
#define BLYNK_DEBUG
//#define APP_DEBUG
#define USE_NODE_MCU_BOARD
#define blynkVirtualPin_1 V0
#define blynkVirtualPin_2 V1
#define blynkVirtualPin_3 V2
#define blynkVirtualPin_4 V3
#define blynkVirtualPin_5 V4
#define blynkVirtualPin_6 V5
#define blynkVirtualPin_7 V6
const uint8_t pinPowerKey[] = {16,5,4,14,12,13,15};
const uint8_t countPowerKey = sizeof(pinPowerKey);
#include "BlynkEdgent.h"
BLYNK_CONNECTED()
Blynk.syncAll();
BLYNK_WRITE(blynkVirtualPin_1){ if(param.asInt() == HIGH) digitalWrite(pinPowerKey[0], HIGH); else digitalWrite(pinPowerKey[0], LOW); }
BLYNK_WRITE(blynkVirtualPin_2){ if(param.asInt() == HIGH) digitalWrite(pinPowerKey[1], HIGH); else digitalWrite(pinPowerKey[1], LOW); }
BLYNK_WRITE(blynkVirtualPin_3){ if(param.asInt() == HIGH) digitalWrite(pinPowerKey[2], HIGH); else digitalWrite(pinPowerKey[2], LOW); }
BLYNK_WRITE(blynkVirtualPin_4){ if(param.asInt() == HIGH) digitalWrite(pinPowerKey[3], HIGH); else digitalWrite(pinPowerKey[3], LOW); }
BLYNK_WRITE(blynkVirtualPin_5){ if(param.asInt() == HIGH) digitalWrite(pinPowerKey[4], HIGH); else digitalWrite(pinPowerKey[4], LOW); }
BLYNK_WRITE(blynkVirtualPin_6){ if(param.asInt() == HIGH) digitalWrite(pinPowerKey[5], HIGH); else digitalWrite(pinPowerKey[5], LOW); }
BLYNK_WRITE(blynkVirtualPin_7){ if(param.asInt() == HIGH) digitalWrite(pinPowerKey[6], HIGH); else digitalWrite(pinPowerKey[6], LOW); }
for(uint8_t i=0; i<countPowerKey; i++){ pinMode(pinPowerKey[i], OUTPUT); digitalWrite(pinPowerKey[i], LOW); }
BlynkEdgent.begin();
BlynkEdgent.run();
Thank you in advance!
