BlynkEdgent.h. It's not in the library
The library does not exist unless you open the example. How do I integrate this into my own code?
Have you installed Blynk library?
If not here is the link :point_up_2:t2:
The Edgent example sketch allows you to use the dynamic provisioning and Blynk.Air OTA functionality.
If you base your sketch on this example then you’ll have that functionality available to you.
