I am using gsm800l with arduino nano to connect my project with blynk2.0 the connection is not completed unless I make irrelevant changes such as commenting some BLYNK_WRITE() functions or change the string to be printed on the monitor; for example when I use:
Serial.print(“pulses=”); Serial.println( pulses);
the cloud could not connect, the serial monitor keep printing the following for ever:
Connecting to blynk.cloud:80
Ready (ping: 1123ms).
Ready (ping: 704ms).
but when I remove some characters as the following it connects:
Serial.print(“pulse=”); Serial.println( pulses);
I tried it many times and the phenomenon is still there, I know this is very strange, I hope there is an explanation, the code is below, thank you in advance:
#define BLYNK_TEMPLATE_ID "xxxxxxxxxxxx"
#define BLYNK_DEVICE_NAME "yyyyy"
#define BLYNK_AUTH_TOKEN "abc"
#define TINY_GSM_MODEM_SIM800
#include <TinyGsmClient.h>
#include <Adafruit_SleepyDog.h>
SoftwareSerial mySerial(7, 6);
#include <EEPROM.h> //
#include <avr/wdt.h> //Watch dog timer functions
#include <elapsedMillis.h>
char apn[] = "internet";
char user[] = "Telenor";
char pass[] = "Telenor";
TinyGsm modem(mySerial);
#define INTERVAL 1000L
#define LS1 3 // last box up
#define LS2 4 // last box down
#define LS3 5 // box 11 down
#define LS4 10 // box 11 up
#define LS5 8 // box 10
#define Pump1 9 //
#define Pump2 16 //
#define Drain 15 //
#define Pump4 13 //
#define Flow_meter 2 //
#define Trubidty 17 //
#define UV 19 //
bool LS1_state; // /***********************************************************************/
bool LS2_state; // /* These variables are used to store the state of the limit swiches, */
bool LS3_state; // /* and it can be obtained from the hardwer directly. */
bool LS4_state; // /* */
bool LS5_state; // /***********************************************************************/
bool Pump1_manual = 0; // /***********************************************************************/
bool Pump2_manual = 0; // /* These variables are used to store the desired state of the pumps, */
bool Drain_pump_manual = 0; // /* and it must be obtained just from the blynk dashboard. */
bool Pump4_manual = 0; // /* */
bool All_pumps = 0; // /***********************************************************************/
byte drain = 0; //
byte count = 0; //
byte full = 0; //
byte on = 0; //
byte EEPROM_Location; //
unsigned int fullPeriod = 0; //
unsigned int drainTime = 0; //
unsigned int ONPeriod = 0; //
unsigned int Writing_times = 0; //
float total; //
float averg; //
float turbidity; //
float flowRate; //
float calibrationFactor = 4.5; // can be removed
float totalMilliLitres = 0; //
float outletVolume = 0; //
int pulses = 0; //
int i=0;
byte reset_times=0;
int reset_times_location=1000;
int online_mode=1;
elapsedMillis Pump1_timer;
elapsedMillis drainTimer;
elapsedMillis EEPROMTime;
elapsedMillis flowTime;
WidgetLED Pump1_indicater(V0);
WidgetLED Pump2_indicater(V1);
WidgetLED Drain_pump(V2);
WidgetLED Pump4_indicater(V3);
//EEPROM_Location = EEPROM.read(0);
// EEPROM_Location = EEPROM_Location * 9;
// outletVolume = EEPROM.get(EEPROM_Location + 3, outletVolume);
// full = EEPROM.read(EEPROM_Location + 7);
// fullPeriod = full * 1000;
// on = EEPROM.read(EEPROM_Location + 8);
// ONPeriod = on * 1000;
// drain = EEPROM.read(EEPROM_Location + 9);
// if(drain > 127){
// drain = drain & 127;
// All_pumps = 1;
// }else All_pumps = 0;
// drainTime = drain * 1000;
void SendDhtData(){
Serial.println("From SendDHtData");
LS1_state = digitalRead(LS1);
LS2_state = digitalRead(LS2);
LS3_state = digitalRead(LS3);
LS4_state = digitalRead(LS4);
LS5_state = digitalRead(LS5);
if(Pump1_timer > fullPeriod) Pump1_timer = 0;
if(All_pumps){
if(Pump1_manual || Pump1_timer < ONPeriod){
Pump1_indicater.on();
digitalWrite(Pump1, LOW);
}else {
Pump1_indicater.off();
digitalWrite(Pump1, HIGH);
if(LS4_state || Pump2_manual){
digitalWrite(Pump2, LOW);
Pump2_indicater.on();
}else if(!LS3_state){
digitalWrite(Pump2, HIGH);
Pump2_indicater.off();
if(LS5_state || Drain_pump_manual){
digitalWrite(Drain, LOW);
Drain_pump.on();
drainTimer = 0;
}else if((!LS5_state) && (drainTimer > drainTime)){
digitalWrite(Drain, HIGH);
Drain_pump.off();
if(LS1_state || Pump4_manual){
digitalWrite(Pump4, LOW);
digitalWrite(UV, LOW);
Pump4_indicater.on();
}else if((!LS2_state)){
digitalWrite(Pump4, HIGH);
digitalWrite(UV, HIGH);
Pump4_indicater.off();
}else{
Drain_pump.off();
// detachInterrupt(digitalPinToInterrupt(2));
// outletVolume = pulses / 486 + outletVolume;
flowTime = 0;
pulses = 0;
Serial.print("pulse="); Serial.println( pulses);
Serial.print("flow rate=");
Serial.println(flowTime);
flowRate = ((1000 / flowTime) * pulses * 0.705) / calibrationFactor;
Serial.print("flow rate=");Serial.println(flowRate);
totalMilliLitres = (flowRate / 60) * 1000000 + totalMilliLitres;
Serial.print("totalMilliLitres=");Serial.println(totalMilliLitres);
flowTime = 0;
pulses = 0;
// //totalMilliLitres += flowMilliLitres;
outletVolume = totalMilliLitres / 1000000;
// //outletVolume = flowRate / 60 + outletVolume;
//Serial.print("flow rate=");Serial.println(flowRate);
Serial.print("outletVolume=");Serial.println(outletVolume);
Blynk.virtualWrite(V12, outletVolume);
Blynk.virtualWrite(V13, flowRate);
if (count < 64){
++count;
total = total + (float)(Trubidty * 0.0008056640625) * 1.52;
if (count >= 64){
averg = (total / count);
turbidity = -1 * 119.7 * (averg - 2.13) + 16.00;
count = 0;
total = 0;
Blynk.virtualWrite(V14, turbidity);
if(EEPROMTime > 60000){
EEPROMTime = 0;
if(EEPROM_Location > 112){
Writing_times = EEPROM.get(EEPROM_Location + 1, Writing_times);
if(Writing_times > 50000){
++EEPROM_Location;
EEPROM.write(0, EEPROM_Location);
Writing_times = 0;
EEPROM.put((EEPROM_Location + 3), outletVolume);
EEPROM.put((EEPROM_Location + 7), full);
EEPROM.put((EEPROM_Location + 8), on);
if(All_pumps) EEPROM.put((EEPROM_Location + 9), (drain | 128));
else EEPROM.put((EEPROM_Location + 9), drain);
++Writing_times;
EEPROM.put((EEPROM_Location + 1), Writing_times);
BLYNK_WRITE(V4){
Pump1_manual = param.asInt();
if(!Pump1_manual){
BLYNK_WRITE(V5){
Pump2_manual = param.asInt();
if(!Pump2_manual){
BLYNK_WRITE(V6){
Drain_pump_manual = param.asInt();
if(!Drain_pump_manual){
Drain_pump.off();
BLYNK_WRITE(V7){
Pump4_manual = param.asInt();
if(!Pump4_manual){
BLYNK_WRITE(V8){
All_pumps = param.asInt();
BLYNK_WRITE(V9){
full = param.asInt();
if(full <= on){
Blynk.virtualWrite(V9, on + 1);
fullPeriod = ONPeriod + 1000;
full = on + 1;
}else fullPeriod = full * 1000;
BLYNK_WRITE(V10){
on = param.asInt();
if(full <= on){
full = on + 1;
BLYNK_WRITE(V11){
drain = param.asInt();
if(drain < 128){
}else{
Blynk.virtualWrite(V11, 127);
drainTime = 127 * 1000;
void interrupt(){
++pulses;
void setup(){
mySerial.begin(9600);
Serial.println("setup");
reset_times= EEPROM.read(reset_times_location);
if(reset_times>=1){
reset_times=0;
EEPROM.write(reset_times_location, reset_times);
Serial.print("1reset_times="); Serial.println(reset_times);
}else{
reset_times=reset_times+1;
Serial.print("2reset_times="); Serial.println(reset_times);
// wdt_disable();
//noInterrupts();
pinMode(LS1, INPUT);
pinMode(LS2, INPUT);
pinMode(LS3, INPUT);
pinMode(LS4, INPUT);
pinMode(LS5, INPUT);
pinMode(Pump1, OUTPUT);
pinMode(Pump2, OUTPUT);
pinMode(Drain, OUTPUT);
pinMode(Pump4, OUTPUT);
pinMode(Flow_meter, INPUT);
pinMode(Trubidty, INPUT);
pinMode(UV, OUTPUT);
if(reset_times<1){
online_mode=1;
Serial.print("online_mode="); Serial.println(online_mode);
Serial.print("reset_times="); Serial.println(reset_times);
modem.restart();
Serial.println("before Blynk.begin");
Serial.println("after Blynk.begin");
}else{
online_mode=0;
reset_times=0;
// EEPROM.write(reset_times, reset_times_location);
// if(Blynk.connect()){
// wdt_enable(WDTO_8S);
// }else{
// wdt_disable();
timer.setInterval(INTERVAL, SendDhtData);
* loop() function
void loop(){
if(online_mode==1){//////////////online mode
if (mySerial.available()) {
Serial.write(mySerial.read());
if (Serial.available()) {
mySerial.write(Serial.read());
if(Blynk.connected()){
Watchdog.enable(8000);
Watchdog.reset();
// Serial.println("Watchdog reset");
// wdt_reset();
// Watchdog.disable();
// wdt_disable();
// Serial.println("wdt disabled");
i=0;
}else{
i++;
Serial.print("i= "); Serial.println(i);
if (i==1000){
Serial.println("watchdog enabled for 8 seconds");
// Serial.println("wdt enabled");
}else{////////offline mode
Watchdog.reset();
// wdt_reset();
// wdt_disable();
i=0;
}else{
i++;
if (i==1000){
Serial.println("watchdog enabled for 75 seconds");
// Blynk.run();
