BLYNK_WRITE(Vpin) can't read without click button
My project is to read virtual pin blynk and send it to node sensor via gateway.
but when i run the program, BLYNK_WRITE not working. Below is my code :
#include "BLEDevice.h"
#include "BLEScan.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
static BLEUUID serviceUUID1("xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx");
static BLEUUID serviceUUID2("xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx");
static BLEUUID serviceUUID3("xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx");
static BLEUUID serviceUUID4("xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx");
static BLEUUID    charUUID("xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx");
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char pass[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
int y=0,z=0;
int x1,x2,x3,x4;
int a=0,b=0,c=0,d=0;
String temp1,temp2,temp3,temp4;
unsigned long _time;
static boolean doConnect = false;
static boolean connected = false;
static boolean doScan = false;
static BLERemoteCharacteristic* pRemoteCharacteristic;
static BLEAdvertisedDevice* myDevice;
void connectnode(){
   if(y==0 && _time==2){
   connectToServer1();
   delay(2000);
   BLEDevice::getScan()->start(0);
   y=1;
   a=1;
    if(y==1 && _time==12){
   connectToServer2();
   delay(2000);
   y=2;
   b=1;
   if(y==2 && _time==22){
   connectToServer3();
   delay(2000);
   y=3;
   c=1;
   if(y==3 && _time==32){
   connectToServer4();
   d=1;
   delay(2000);
   //ESP.restart();
    if(a==1 && b==1 && c==1 && d==1){
  Serial.print(a);
  Serial.print(b);
  Serial.println(c);
  delay(3000);
  while(connected = true){
  if(x1==1 || x2==1 || x3==1 || x4==1){
    connected=false;
  a=0;
  b=0;
  c=0;
  d=0;
  y=0;
BLYNK_WRITE(V5)
  x1 = param.asInt();
  Serial.println(param.asInt());
BLYNK_WRITE(V6)
  x2 = param.asInt();
BLYNK_WRITE(V7)
  x3 = param.asInt();
BLYNK_WRITE(V8)
  x4 = param.asInt();
static void notifyCallback(
  BLERemoteCharacteristic* pBLERemoteCharacteristic,
  uint8_t* pData,
  size_t length,
  bool isNotify) {
    Serial.print("Notify callback for characteristic ");
    Serial.print(pBLERemoteCharacteristic->getUUID().toString().c_str());
    Serial.print(" of data length ");
    Serial.println(length);
    Serial.print("data: ");
    Serial.println((char*)pData);
class MyClientCallback : public BLEClientCallbacks {
  void onConnect(BLEClient* pclient) {
  void onDisconnect(BLEClient* pclient) {
    connected = false;
    Serial.println("onDisconnect");
bool connectToServer1() {
    Serial.print("Forming a connection to ");
    Serial.println(myDevice->getAddress().toString().c_str());
    BLEClient*  pClient  = BLEDevice::createClient();
    Serial.println(" - Created client");
    pClient->setClientCallbacks(new MyClientCallback());
    pClient->connect(myDevice);
    Serial.println(" - Connected to server");
    BLERemoteService* pRemoteService = pClient->getService(serviceUUID1);
    if (pRemoteService == nullptr) {
      Serial.print("Failed to find our service UUID: ");
      Serial.println(serviceUUID1.toString().c_str());
      pClient->disconnect();
      return false;
    Serial.println(" - Found our service");
    pRemoteCharacteristic = pRemoteService->getCharacteristic(charUUID);
    if (pRemoteCharacteristic == nullptr) {
      Serial.print("Failed to find our characteristic UUID: ");
      Serial.println(charUUID.toString().c_str());
      return false;
    Serial.println(" - Found our characteristic");
    if(pRemoteCharacteristic->canRead()) {
      std::string value = pRemoteCharacteristic->readValue();
      Serial.print("The characteristic value was: ");
      Serial.println(value.c_str());
      Serial.print("Received Value: ");
      Serial.println("*********");
      String totalString = value.c_str();
      temp1 = totalString.substring(0,1);
  if(temp1 == "0"){
     Blynk.virtualWrite(V1,"Kontak1 : Normal");
  if(temp1 == "1"){
     Blynk.virtualWrite(V1,"Kontak1 : Mati");
      Serial.print("Node Sensor 1 : ");
      Serial.println(x1);
      if(x1==1){
      pRemoteCharacteristic->writeValue("1");}
      if(x1==0){
      pRemoteCharacteristic->writeValue("0");}
bool connectToServer2() {
    BLERemoteService* pRemoteService = pClient->getService(serviceUUID2);
      Serial.println(serviceUUID2.toString().c_str());
      return false;
      return false;
      temp2 = totalString.substring(0,1);
  if(temp2 == "0"){
     Blynk.virtualWrite(V2,"Kontak2 : Normal");
  if(temp2 == "1"){
     Blynk.virtualWrite(V2,"Kontak2 : Mati");
      Serial.print("Node Sensor 2 : ");
      Serial.println(x1);
      if(x2==1){
      if(x2==0){
bool connectToServer3() {
    BLERemoteService* pRemoteService = pClient->getService(serviceUUID3);
      Serial.println(serviceUUID3.toString().c_str());
      return false;
      return false;
      temp3 = totalString.substring(0,1);
  if(temp3 == "0"){
     Blynk.virtualWrite(V3,"Kontak3 : Normal");
  if(temp3 == "1"){
     Blynk.virtualWrite(V3,"Kontak3 : Mati");
      Serial.print("Node Sensor 3 : ");
      Serial.println(x1);
      if(x3==1){
      if(x3==0){
bool connectToServer4() {
    BLERemoteService* pRemoteService = pClient->getService(serviceUUID4);
      Serial.println(serviceUUID4.toString().c_str());
      return false;
      return false;
      temp4 = totalString.substring(0,1);
  if(temp4 == "0"){
     Blynk.virtualWrite(V4,"Kontak4 : Normal");
  if(temp4 == "1"){
     Blynk.virtualWrite(V4,"Kontak4 : Mati");
      Serial.print("Node Sensor 4 : ");
      Serial.println(x1);
      if(x4==1){
      if(x4==0){
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
  void onResult(BLEAdvertisedDevice advertisedDevice) {
    Serial.print("BLE Advertised Device found: ");
    Serial.println(advertisedDevice.toString().c_str());
    if (z == 0 && advertisedDevice.haveServiceUUID() && advertisedDevice.isAdvertisingService(serviceUUID1)) {
      BLEDevice::getScan()->stop();
      myDevice = new BLEAdvertisedDevice(advertisedDevice);
      doScan = true;
      z=1;
   if (z == 1 && advertisedDevice.haveServiceUUID() && advertisedDevice.isAdvertisingService(serviceUUID2)) {
      doScan = true;
      z=2;
   if (z == 2 && advertisedDevice.haveServiceUUID() && advertisedDevice.isAdvertisingService(serviceUUID3)) {
      doScan = true;
      z=3;
   if (z == 3 && advertisedDevice.haveServiceUUID() && advertisedDevice.isAdvertisingService(serviceUUID4)) {
      doScan = true;
      z=0;
  BLEDevice::init("");
  BLEScan* pBLEScan = BLEDevice::getScan();
  pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
  pBLEScan->setInterval(1349);
  pBLEScan->setWindow(449);
  pBLEScan->setActiveScan(true);
  pBLEScan->start(5, false);
    _time = (millis()/1000)%40;
    connectnode();
    connected=false;
while i use this code, BLYNK_WRITE working but not want to out from looping and it must click button on blynk apps so that param.asInt() can display the value.
BLYNK_WRITE(vPin) is a callback function that triggers when the value of the virtual pin changes on the server. That is the whole purpose of this callback and this is why you are seeing this behaviour.
You can force the BLYNK_WRITE(vPin) callback to fire by calling Blynk.syncVirtual(vPin), and this would normally be called in the BLYNK_CONNECTED() callback, which fires whenever your device connects or re-connects to the server.
The normal way to handle things is to declare a GLOBAL variable that will hold the current state of your virtual pin so that it can be referenced from anywhere within your code at any time. When the board boots then your BLYNK_CONNECTED() callback will fire, and you’ll have a Blynk.syncVirtual(vPin) command within that callback.
This causes the BLYNK_WRITE(vPin) callback to fire, and this is where you’ll store the current vPin value to your global variable.
BLYNK_CONNECTED()
  Blynl.syncVirtial(vPin);
BLYNK_WRITE(vPin)
  myGlobalVariable = param.asInt();
Also, your void loop is incompatible with Blynk. You should read this:
