BLYNK_WRITE() in for loop?
I’m using NodeMCU ESP8266 with Blynk v0.6.1 library; please help me to refactor my code.
I just need to know:
  1. Is there a way to define virtual pin array instead of multiple variables?
  2. Can we make BLYNK_WRITE(Vx) in for loop?
#define VPIN_BTN_0  V0
#define VPIN_BTN_1  V1
#define VPIN_BTN_2  V2
BLYNK_WRITE(VPIN_BTN_0) {
  relayState[0] = param.asInt();
  shiftWrite(0, relayState[0]);
BLYNK_WRITE(VPIN_BTN_1) {
  relayState[1] = param.asInt();
  shiftWrite(1, relayState[1]);
BLYNK_WRITE(VPIN_BTN_2) {
  relayState[2] = param.asInt();
  shiftWrite(2, relayState[2]);
Can you explain more about what you’re trying to achieve?
Something like that ?
int Sync[] = {1, 3, 6, 7, 8, 15, 16, 17, 19, 23, 27, 28, 45, 46];
void setup(){
 const int vSync = ( sizeof Sync ) / ( sizeof Sync[0] );
  while (Vcount < vSync + 1) {
    Vcount++;
    Blynk.syncVirtual(Sync[Vcount]);  // Generate a vPin sync for each count
Basically I’m using SN74HC595 shift resistor for extending GPIOs of my ESP8266. The shiftWrite(1, relayState[1]); function is for addressing SN74HC595 pins. I’ve 6 relay with 6 physical buttons and I’m doing BLYNK_WRITE(VPIN_BTN) on every physical button, therefore my code is getting so lengthy and repetitive. So I want to know if there is a way to reduce my code.
Yeah, I think just like that example you’ve shared… I’ve defined my int relayState[] = { 1, 1, 1, 1, 1, 1 }; in array but how can I define a virtual pins array so I can use that array with index in BLYNK_WRITE(VPIN_BTN[i]) and group that 6 BLYNK_WRITE() handler into a for loop?
There was also repeated code in my void setup() function, but check code below; how I reduced it with for loop, this is what I need.
  // Set the three SPI pins to be outputs
  pinMode(DATA_PIN, OUTPUT);
  pinMode(LATCH_PIN, OUTPUT);
  pinMode(CLOCK_PIN, OUTPUT);
  for (int i = 0; i <= 5; i++) {
    // Turn off all relays
    shiftWrite(i, HIGH);
    // Restore previous states of relays
    pinMode(BTN_PIN[i], INPUT_PULLUP);
    shiftWrite(i, relayState[i]);
I really don’t understand that statement at all. Do you mean on every widget button?
If you’re trying to reduce the code then you could look at BLYNK_WRITE_DEFAULT() :
https://docs.blynk.cc/#blynk-firmware-blynktimer-blynk_write_default
I’ve never used it, but it appears that it would allow to to parameterise the virtual pin that triggered the callback.
Yes.
Have a look at my messy code :no_mouth:
#include "settings.h"
#include "wifimanagment.h"
#include "shiftwrite.h"
/* SN74HC595 Connections */
/* Controls the internal transference of data in SN74HC595 internal registers */
const int LATCH_PIN = 16; // D0 - Connected to ST_CP
/* Generates the clock signal to control the transference of data */
const int CLOCK_PIN = 5;  // D1 - Connected to SH_CP
/* Outputs the byte to transfer */
const int DATA_PIN = 4;   // D2 - Connected to DS
/* NodeMCU to Push Button switch */
// D3, D4, D5, D6, D7, RX
int BTN_PIN[] = {0, 2, 14, 12, 13, 3};
/* Blynk Virtual Pin Assignment */
#define VPIN_BTN_3  V3
#define VPIN_BTN_4  V4
#define VPIN_BTN_5  V5
void checkPhysicalButton();
int btnState[] = { 1, 1, 1, 1, 1, 1 };
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
  //for (int i = 0; i <= 5; i++) {
  //  Blynk.syncVirtual(VPIN_BTN[i]);
  Blynk.syncVirtual(VPIN_BTN_0, VPIN_BTN_1, VPIN_BTN_2, VPIN_BTN_3, VPIN_BTN_4, VPIN_BTN_5);
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BTN_3) {
  relayState[3] = param.asInt();
  shiftWrite(3, relayState[3]);
BLYNK_WRITE(VPIN_BTN_4) {
  relayState[4] = param.asInt();
  shiftWrite(4, relayState[4]);
BLYNK_WRITE(VPIN_BTN_5) {
  relayState[5] = param.asInt();
  shiftWrite(5, relayState[5]);
void checkPhysicalButton() {
  if (digitalRead(BTN_PIN[0]) == 0) {
    // btnState[] is used to avoid sequential toggles
    if (btnState[0] != 0) {
      // Toggle RELAY state
      relayState[0] = !relayState[0];
      // Update Button Widget
      Blynk.virtualWrite(VPIN_BTN_0, relayState[0]);
    btnState[0] = 0;
    btnState[0] = 1;
  if (digitalRead(BTN_PIN[1]) == 0) {
    if (btnState[1] != 1) {
      relayState[1] = !relayState[1];
      Blynk.virtualWrite(VPIN_BTN_1, relayState[1]);
    btnState[1] = 0;
    btnState[1] = 1;
  if (digitalRead(BTN_PIN[2]) == 0) {
    if (btnState[2] != 0) {
      relayState[2] = !relayState[2];
      Blynk.virtualWrite(VPIN_BTN_2, relayState[2]);
    btnState[2] = 0;
    btnState[2] = 1;
  if (digitalRead(BTN_PIN[3]) == 0) {
    if (btnState[3] != 0) {
      relayState[3] = !relayState[3];
      Blynk.virtualWrite(VPIN_BTN_3, relayState[3]);
    btnState[3] = 0;
    btnState[3] = 1;
  if (digitalRead(BTN_PIN[4]) == 0) {
    if (btnState[4] != 0) {
      relayState[4] = !relayState[4];
      Blynk.virtualWrite(VPIN_BTN_4, relayState[4]);
    btnState[4] = 0;
    btnState[4] = 1;
  if (digitalRead(BTN_PIN[5]) == 0) {
    if (btnState[5] != 0) {
      relayState[5] = !relayState[5];
      Blynk.virtualWrite(VPIN_BTN_5, relayState[5]);
    btnState[5] = 0;
    btnState[5] = 1;
  EEPROM.begin(memalloc);
  delay(100);
    // Turn off all RELAYS
    // Restore previous RELAYS states
  // Setup a function to be called every 100 ms
  timer.setInterval(100L, checkPhysicalButton);
  if(connectWifi()){
    Blynk.begin(auth, ssid, password);
    startAP();
  if(WiFi.status() == WL_CONNECTED){
  } else{
    startAP();
Okay, looks like the BLYNK_WRITE_DEFAULT() callback would tidy-up that part of your code, and a ‘for’ loop on your physical switch polling would help a lot.
Thanks you @PeteKnight for enlighten my day, now…
My previous code:
Will become:
BLYNK_WRITE_DEFAULT() {
  int pin = request.pin; // determines what vPin is triggering this response
  relayState[pin] = param.asInt();
  shiftWrite(pin, relayState[pin]);
You can use array of struct to do the job more efficient this way"
// Comment out as no full code exists
//#include "settings.h"
//#include "wifimanagment.h"
//#include "shiftwrite.h"
#include <EEPROM.h>
// Pin GPIO3
#define RX    3
#define NUM_OF_RELAYS      6
typedef struct
  const int vPin;
  const int buttonPin;
  bool relayState;
  bool btnState;
} Relay_Property_t;
Relay_Property_t relayArray[NUM_OF_RELAYS] =
  { V0, D3, true, true },
  { V1, D4, true, true },
  { V2, D5, true, true },
  { V3, D6, true, true },
  { V4, D7, true, true },
  { V5, RX, true, true }
BLYNK_CONNECTED() {
 for (int i = 0; i < NUM_OF_RELAYS; i++)
  Blynk.syncVirtual(relayArray[i].vPin);
// BLYNK_WRITE can't be optimized by putting in a loop
// Can't use BLYNK_WRITE(relayArray[0].vPin)
  int index = 0;
  relayArray[index].relayState = param.asInt();
  shiftWrite(index, relayArray[index].relayState);
  int index = 1;
  int index = 2;
  int index = 3;
  int index = 4;
  int index = 5;
    if (digitalRead(relayArray[i].buttonPin) == 0)
        if (relayArray[i].btnState)
          relayArray[i].relayState = !relayArray[i].relayState;
          shiftWrite(0, relayArray[i].relayState);
          Blynk.virtualWrite(relayArray[i].vPin, relayArray[i].relayState);
        relayArray[i].btnState = false;
      relayArray[i].btnState = true;
// Fake function to satisfy compiler
void shiftWrite(int i, bool relayState)
bool connectWifi()
  return true;
void startAP()
char auth[]     = "***";
char ssid[]     = "***";
char password[] = "***";
  //EEPROM.begin(memalloc);
  EEPROM.begin(2048);
  delay(100);
    pinMode(relayArray[i].buttonPin, INPUT_PULLUP);
    shiftWrite(i, relayArray[i].relayState);
  if(connectWifi()){
    startAP();
  } else{
    startAP();
