Hello everyone, i have 6 sensors and 4 led on my circuit. And 4 button for leds. After blynk connected i am getting last status of led. But after my all sensor read i cant control the buttons. When sensor read not completed i can control leds with button but after the sensor read connection drops. Can someone help me ? Thanks for the help
#define BLYNK_PRINT SwSerial
#include <LiquidCrystal.h>
LiquidCrystal lcd(13, 12, 11, 10, 9, 8);
#define ledPin1 4
#define ledPin2 5
#define ledPin3 6
#define ledPin4 7
#define vPin1 V12
#define vPin2 V13
#define vPin3 V14
#define vPin4 V15
#define sensor1 A0
#define sensor2 A1
#define sensor3 A2
#define sensor4 A3
#define sensor5 A4
float temp;
char auth[] = "Rn4MzFKwTAxOIljim9N_O6mGI3XUtgcQ";
int i=0;
int switch_1_ON = 0;
int ledPinState1 = LOW;
int ledPinState2 = LOW;
int ledPinState3 = LOW;
int ledPinState4 = LOW;
BLYNK_CONNECTED() {
Blynk.syncVirtual(vPin1);
Blynk.syncVirtual(vPin2);
Blynk.syncVirtual(vPin3);
Blynk.syncVirtual(vPin4);
// Alternatively, you could override server state using:
// Blynk.virtualWrite(VPIN_BUTTON_1, relay1State);
// Blynk.virtualWrite(VPIN_BUTTON_2, relay2State);
// Blynk.virtualWrite(VPIN_BUTTON_3, relay3State);
// Blynk.virtualWrite(VPIN_BUTTON_4, relay4State);
void oku(){
//sensör 1 için
int SensorValue = analogRead(sensor1);
float SensorVolts = analogRead(sensor1)*0.0048828125;
float SensorYuzde= analogRead(sensor1)/10;
if(SensorYuzde >= 100){
SensorYuzde = 100;
Blynk.virtualWrite(V5,SensorYuzde);
//sensor 2 için
int SensorValue2 = analogRead(sensor2);
float SensorVolts2 = analogRead(sensor2)*0.0048828125;
float SensorYuzde2= analogRead(sensor2)/10;
if(SensorYuzde2 >= 100){
SensorYuzde2 = 100;
Blynk.virtualWrite(V6,SensorYuzde2);
//sensor 3 için
int SensorValue3 = analogRead(sensor3);
float SensorVolts3 = analogRead(sensor3)*0.0048828125;
float SensorYuzde3= analogRead(sensor3)/10;
if(SensorYuzde3 >= 100){
SensorYuzde3 = 100;
Blynk.virtualWrite(V2,SensorYuzde3);
//sensor 4 için
int SensorValue4 = analogRead(sensor4);
float SensorVolts4 = analogRead(sensor4)*0.0048828125;
float SensorYuzde4= analogRead(sensor4)/10;
if(SensorYuzde4 >= 100){
SensorYuzde4 = 100;
Blynk.virtualWrite(V1,SensorYuzde4);
//sensor water için
int SensorValue5 = analogRead(sensor5);
float SensorVolts5 = analogRead(sensor5)*0.0048828125;
float SensorYuzde5= analogRead(sensor5)/10;
if(SensorYuzde5 >= 100){
SensorYuzde5 = 100;
Blynk.virtualWrite(V4,SensorYuzde5);
//sıcaklık için
temp= analogRead(A5);
int temperature = (temp * 500)/1024;
Blynk.virtualWrite(V3,temperature);
lcd.setCursor(14, 2);
lcd.print(SensorValue);
lcd.setCursor(9, 3);
lcd.print(SensorVolts);
lcd.print(" V");
/*int sensorOkuma(int SensorPin){
int Value = analogRead(SensorPin);
float volts = analogRead(SensorPin)*0.0048828125;
float yuzde= analogRead(SensorPin)/10;
if(yuzde >= 100){
yuzde = 100;
return yuzde;
BLYNK_WRITE(vPin1) {
ledPinState1 = param.asInt();
digitalWrite(ledPin1, ledPinState1);
BLYNK_WRITE(vPin2) {
ledPinState2 = param.asInt();
digitalWrite(ledPin2, ledPinState2);
BLYNK_WRITE(vPin3) {
ledPinState3 = param.asInt();
digitalWrite(ledPin3, ledPinState3);
BLYNK_WRITE(vPin4) {
ledPinState4 = param.asInt();
digitalWrite(ledPin4, ledPinState4);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
digitalWrite(ledPin3,ledPinState3);
pinMode(ledPin4, OUTPUT);
digitalWrite(ledPin4,ledPinState4);
// set up the LCD's number of columns and rows:
lcd.begin(20, 4);
// Print a message to the LCD.
lcd.setCursor(0,2);
lcd.print("Analog Value: ");
lcd.setCursor(0,3);
lcd.print("Voltage: ");
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
timer.setInterval(500L, oku);
