Apologies if this has already been answered but I have spent 2 solid days scouring the forum and my issues still are not fixed.
I am trying to build a simple temperature / humidity sensor for environmental monitoring on an Arduino Nano which communicates to Blynk (library version 0.54 / app verson 2.27.1) on Andrioid version 8.0.0 on a Galaxy S8.
The hardware being used is an Arduino Nano + DSD Tech HM10 BLE module.
Just to update on what I have already checked, I was originally using software serial and having the exact same issue and was using the correct 10 / 11 pins for RX / TX.
About an hour ago to check if software serial was the issue I moved to Altsoftserial on pins 8 and 9 RX/TX. Getting the exact same issue.
I have tested the BLE module with App Inventor 2, this works perfectly however app inventor doesn’t have some of the features I need well documented so I thought as I have a relatively tight deadline, Blynk would be easier.
Also if I beam out temp data through BLE and test with any BLE scanner, I can see the temp data being logged and beamed over bluetooth.
All the issues with the system appear to be with the Blynk app. I can rarely (1 in every 20+ tries) get the app using the BLE widget to connect, the blinking LED on the HM10 turns solid to show a connection has been made. This will then disconnect after 30 seconds or so.
In the serial I mainly just get connecting… login timeout.with the Auth token packets being beamed out in 2 times (I assume as it is over the 20 char limit).
When it does connect, I cannot get anything to show up in the app in any of the widgets. I am pushing to virtual pin V5 but I have never managed to get any data show up.
Below is the latest incaration of code, I am using the Blynk example code which generates random fake temp data (I wanted to eliminate any issues with the analog pin read), and dumps it to V5.
http://twitter.com/blynk_app
Warning: Bluetooth support is in beta!
You can construct and display any strings on a Value Display.
App project setup:
Value Display widget attached to V5
#define BLYNK_DEBUG
#include <AltSoftSerial.h>
AltSoftSerial SerialBLE;
char auth[] = "6fe0f069xxxxxxxxx868cec630584d5";
void sendTemperature()
// Generate random temperature value 10.0 to 30.0 (for example)
float t = float(random(100, 300)) / 10;
// Format: 1 decimal place, add ℃
String str = String(t, 1) + "℃";
// Send it to the server
Blynk.virtualWrite(V5, str);
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
timer.setInterval(1000L, sendTemperature);
Debug serial output:
[2349029] <[02|00|01|00] 6fe0f069xxxxxx
[2349071] <ab5868cec630584d5
[2352112] Login timeout
[2354112] Connecting...
[2354112] <[02|00|01|00] 6fe0f069xxxxxxx
[2354154] <ab5868cec630584d5
[2357195] Login timeout
[2359195] Connecting...
[2359195] <[02|00|01|00] 6fe0f0xxxxxxxx
[2359237] <ab5868cec630584d5
[2362278] Login timeout
[2364278] Connecting...
[2364278] <[02|00|01|00] 6fe0f0xxxxxxx
[2364320] <ab5868cec630584d5
[2367361] Login timeout
[2369361] Connecting...
[2369361] <[02|00|01|00] 6fe0f06xxxxxxxx
[2369403] <ab5868cec630584d5
When it actually manages to connect, I can see the data being beamed over in the debug:
[503357] Ready
[503373] Free RAM: 1155
[503400] <[00|00|01|00|C8]
[504469] <[14|00|02|00|0C]vw[00]5[00]10.7[E2|84|83]
[505469] <[14|00|03|00|0C]vw[00]5[00]14.9[E2|84|83]
[506469] <[14|00|04|00|0C]vw[00]5[00]17.3[E2|84|83]
[507469] <[14|00|05|00|0C]vw[00]5[00]15.8[E2|84|83]
[508469] <[14|00|06|00|0C]vw[00]5[00]23.0[E2|84|83]
[509469] <[14|00|07|00|0C]vw[00]5[00]17.2[E2|84|83]
[510469] <[14|00|08|00|0C]vw[00]5[00]24.4[E2|84|83]
[511469] <[14|00|09|00|0C]vw[00]5[00]17.8[E2|84|83]
[512470] <[14|00|0A|00|0C]vw[00]5[00]22.3[E2|84|83]
[513357] <[06|00|0B|00|00]
[513469] <[14|00|0C|00|0C]vw[00]5[00]20.9[E2|84|83]
[514469] <[14|00|0D|00|0C]vw[00]5[00]14.0[E2|84|83]
[515469] <[14|00|0E|00|0C]vw[00]5[00]26.5[E2|84|83]
[516358] <[06|00|0F|00|00]
[516469] <[14|00|10|00|0C]vw[00]5[00]19.2[E2|84|83]
[517469] <[14|00|11|00|0C]vw[00]5[00]14.2[E2|84|83]
[518469] <[14|00|12|00|0C]vw[00]5[00]28.7[E2|84|83]
[519359] <[06|00|13|00|00]
[519469] <[14|00|14|00|0C]vw[00]5[00]20.3[E2|84|83]
[520469] <[14|00|15|00|0C]vw[00]5[00]22.7[E2|84|83]
[521469] <[14|00|16|00|0C]vw[00]5[00]22.9[E2|84|83]
[522357] Heartbeat timeout: 522357, 503356, 519359
Also when it does connect, I notice it manages to send the full Auth token properly (not split into 2 lines)
[503254] <[02|00|01|00] 6fe0f06xxxxxxxxxx
[503294] <ab5868cec630584d5
[503334] >[02|00|01|00]
[503335] >6fe0f06xxxxxxxxxb5868cec630584d5
[503357] Ready
I am all out of ideas on how to solve this. I have tested every piece of example code and cannot get anything to connect consistently and when it connects I have never received a single value in the Blynk app.
Any help would be appreciated, I have tried to be as comprehensive as possible and apologies if my post is messy, had a couple of sleepless nights on this one!
Thanks!
