Update Apr 8th 2020
Releases v1.0.10
- WiFi Password max length now is 63, according to WPA2 standard
- Permit to input special chars such as % and # into data fields. Thanks to brondolin to provide the amazing fix. See Issue 3.
Update Apr 9th 2020
Releases v1.0.11
Severe connecting bug. Please don’t use v1.0.11
- New powerful-yet-simple-to-use feature to enable adding dynamic custom parameters from sketch and input using the same Config Portal. Config Portal will be auto-adjusted to match the number of dynamic parameters.
- Dynamic custom parameters to be saved automatically in EEPROM, or SPIFFS.
By just adding the following sample code snippet, you can add dynamic parameters and use them i your sketch. For example: MQTT Credentials, etc.
#define USE_DYNAMIC_PARAMETERS true
/////////////// Start dynamic Credentials ///////////////
//Defined in <BlynkSimpleEsp8266_WM.h> and <BlynkSimpleEsp8266_SSL_WM.h>
#define MAX_ID_LEN 5
#define MAX_DISPLAY_NAME_LEN 16
typedef struct
char id [MAX_ID_LEN + 1];
char displayName [MAX_DISPLAY_NAME_LEN + 1];
char *pdata;
uint8_t maxlen;
} MenuItem;
#if USE_DYNAMIC_PARAMETERS
#define MAX_MQTT_SERVER_LEN 34
char MQTT_Server [MAX_MQTT_SERVER_LEN + 1] = "";
#define MAX_MQTT_PORT_LEN 6
char MQTT_Port [MAX_MQTT_PORT_LEN + 1] = "";
#define MAX_MQTT_USERNAME_LEN 34
char MQTT_UserName [MAX_MQTT_USERNAME_LEN + 1] = "";
#define MAX_MQTT_PW_LEN 34
char MQTT_PW [MAX_MQTT_PW_LEN + 1] = "";
#define MAX_MQTT_SUBS_TOPIC_LEN 34
char MQTT_SubsTopic [MAX_MQTT_SUBS_TOPIC_LEN + 1] = "";
#define MAX_MQTT_PUB_TOPIC_LEN 34
char MQTT_PubTopic [MAX_MQTT_PUB_TOPIC_LEN + 1] = "";
MenuItem myMenuItems [] =
{ "mqtt", "MQTT Server", MQTT_Server, MAX_MQTT_SERVER_LEN },
{ "mqpt", "Port", MQTT_Port, MAX_MQTT_PORT_LEN },
{ "user", "MQTT UserName", MQTT_UserName, MAX_MQTT_USERNAME_LEN },
{ "mqpw", "MQTT PWD", MQTT_PW, MAX_MQTT_PW_LEN },
{ "subs", "Subs Topics", MQTT_SubsTopic, MAX_MQTT_SUBS_TOPIC_LEN },
{ "pubs", "Pubs Topics", MQTT_PubTopic, MAX_MQTT_PUB_TOPIC_LEN },
uint16_t NUM_MENU_ITEMS = sizeof(myMenuItems) / sizeof(MenuItem); //MenuItemSize;
#else
MenuItem myMenuItems [] = {};
uint16_t NUM_MENU_ITEMS = 0;
#endif
/////// // End dynamic Credentials ///////////
- If you don’t need to add dynamic parameters, use the following in sketch
#define USE_DYNAMIC_PARAMETERS false
or
First, connect your (PC, Laptop, Tablet, phone, etc.) WiFi to Config Portal AP, then enter the WiFi password :
After you connected, please, go to http://192.168.4.1 or the configured AP IP. The Config Portal screen will appear:
Enter your WiFi and Blynk Credentials:
Important notes
- Now you can use hash tag # or % thanks to brondolin to provide the amazing fix in v1.0.10 to permit input special chars such as % and # into data fields. See Issue 3.
- The SSIDs, Passwords, BlynkServers and Tokens must be input (or to make them different from nothing). Otherwise, the Config Portal will re-open until those fields have been changed. If you don’t need any field, just input anything or use duplicated data from similar field.
- WiFi password max length now is 63 chars according to WPA2 standard.
Then click Save
. The system will auto-restart. You will see the board’s built-in LED turned OFF. That means, it’s already connected to your Blynk server successfully.
Updated April 13th 2020
Releases v1.0.12
- Fix severe bug in v1.0.11
Updated April 26th 2020
Major Releases v1.0.13
Releases v1.0.13
- Optional default Credentials as well as Dynamic parameters to be optionally autoloaded into Config Portal to use or change instead of manually input.
- DoubleDetectDetector feature to force Config Portal when double reset is detected within predetermined time, default 10s.
- Configurable Config Portal Title to be either HostName, BoardName or default undistinguishable names.
- Examples are redesigned to separate Credentials / Defines / Dynamic Params / Code so that you can change Credentials / Dynamic Params quickly for each device.
Thanks to thorathome in GitHub and thorathome in Blynk to test, suggest and encourage to add those new features in v1.0.13, such as Default Credentials/Dynamic Parms, Configurable Config Portal Title, DRD. See WM Config Portal using BlynkSimpleEsp32/8266_WM.h.
So, how it works?
If it cannot connect to the Blynk server in 30 seconds, no valid stored Credentials or Double Reset is detected within 10s, it will switch to Configuration Mode
. You will see your built-in LED turned ON. In Configuration Mode
, it starts an AP with default name ESP_xxxxxx
and password MyESP_xxxxxx
or configurable name and password you specified. The AP IP address is default at 192.168.4.1
or configured IP (e.g. 192.168.200.1
- If you choose not to load default Credentials and Dynamic Parameters
After you connected, please, go to http://192.168.4.1 or the configured AP IP. The following Config Portal screen will appear:
- If you choose to load default Credentials and Dynamic Parameters
Then click Save. The system will auto-restart. You will see the board’s built-in LED turned OFF. That means, it’s already connected to your Blynk server successfully.
Important notes
- Now you can use special chars such as ~, !, @, #, $, %, ^, &, _, -, space,etc. thanks to brondolin to provide the amazing fix in v1.0.10 to permit input special chars such as % and # into data fields. See Issue 3.
- Sometimes, it’s hard or not possible to connect to Config Portal WiFi AP, the majority cases are caused by WiFi channel conflict if there are too many WiFi APs running around. Please use random ConfigPortal WiFi AP channel in sketch (see code snippet below) and reset the board so that another channel is used. Repeat until connection is OK
// Set config portal channel, default = 1. Use 0 => random channel from 1-13 to avoid conflict
Blynk.setConfigPortalChannel(0);
How to use default Credentials and have them pre-loaded onto Config Portal
See this example and modify as necessary
- To load Default Credentials
bool LOAD_DEFAULT_CONFIG_DATA = true;
- To use system default to load “blank” when there is no valid Credentials
bool LOAD_DEFAULT_CONFIG_DATA = false;
- Example of Default Credentials
/// Start Default Config Data //////////////////
// Defined in <BlynkSimpleEsp32_WM.h> and <BlynkSimpleEsp32_SSL_WM.h>
#define SSID_MAX_LEN 32
#define PASS_MAX_LEN 64
typedef struct
char wifi_ssid[SSID_MAX_LEN];
char wifi_pw [PASS_MAX_LEN];
} WiFi_Credentials;
#define BLYNK_SERVER_MAX_LEN 32
#define BLYNK_TOKEN_MAX_LEN 36
typedef struct
char blynk_server[BLYNK_SERVER_MAX_LEN];
char blynk_token [BLYNK_TOKEN_MAX_LEN];
} Blynk_Credentials;
#define NUM_WIFI_CREDENTIALS 2
#define NUM_BLYNK_CREDENTIALS 2
typedef struct Configuration
char header [16];
WiFi_Credentials WiFi_Creds [NUM_WIFI_CREDENTIALS];
Blynk_Credentials Blynk_Creds [NUM_BLYNK_CREDENTIALS];
int blynk_port;
char board_name [24];
int checkSum;
} Blynk_WM_Configuration;
//bool LOAD_DEFAULT_CONFIG_DATA = false;
Blynk_WM_Configuration defaultConfig =
//char header[16], dummy, not used
#if USE_SSL
"SSL",
#else
"NonSSL",
#endif
//WiFi_Credentials WiFi_Creds [NUM_WIFI_CREDENTIALS]
//WiFi_Creds.wifi_ssid and WiFi_Creds.wifi_pw
"SSID1", "password1",
"SSID2", "password2",
// Blynk_Credentials Blynk_Creds [NUM_BLYNK_CREDENTIALS];
// Blynk_Creds.blynk_server and Blynk_Creds.blynk_token
"account.ddns.net", "token",
"account.duckdns.org", "token1",
//int blynk_port;
#if USE_SSL
9443,
#else
8080,
#endif
//char board_name [24];
"Air-Control",
//int checkSum, dummy, not used
0
/////////// End Default Config Data /////////////
How to add dynamic parameters from sketch
- To add custom parameters, just modify from the example below
//Defined in <BlynkSimpleEsp32_WM.h> and <BlynkSimpleEsp32_SSL_WM.h>
typedef struct
char *pdata;
uint8_t maxlen;
} MenuItem;
char MQTT_Server [MAX_MQTT_SERVER_LEN + 1] = "default-mqtt-server";
char MQTT_Port [MAX_MQTT_PORT_LEN + 1] = "1883";
char MQTT_UserName [MAX_MQTT_USERNAME_LEN + 1] = "default-mqtt-username";
char MQTT_PW [MAX_MQTT_PW_LEN + 1] = "default-mqtt-password";
char MQTT_SubsTopic [MAX_MQTT_SUBS_TOPIC_LEN + 1] = "default-mqtt-SubTopic";
char MQTT_PubTopic [MAX_MQTT_PUB_TOPIC_LEN + 1] = "default-mqtt-PubTopic";
#else
#endif
or
