Blynk webhook
Hi! I have an arduino sending data to blynk, monitoring some climate conditions. I want to use weebhook widget to send those data to ThingSpeak, I dont understand how does the multi pin works, I mean, can I send all that data trough a single pin or I need to use one webhook widget for each value?
Yes you can.
Thanks for your response @Costas! How can I do that?
Search docs for “multi value pin”.
Ok, thank you!
