Blynk.virtualWrite() not working
Hi I make a project on shop security system. If anyone wants to try to enter in room blynk send a notification to owner and all appliances can be control through blynk apps. It perfectly work for couple of hours. But after few hours blynk notification does not working and if I control appliances by bluetooth or manual switch not reflected on blynk platform which previously working. I think there may be problem in Blynk.virtualWrite(); Please help me. I upload my program below.
Please note blynk show online and can be controlled through blynk.
#define BLYNK_TEMPLATE_ID "xxxxxxxxx"
#define BLYNK_TEMPLATE_NAME "xxxxxxxxxx"
#define BLYNK_AUTH_TOKEN "xxxxxxxxx"
#include <BlynkSimpleEsp32.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BluetoothSerial.h>
#include <Preferences.h>
#include <AceButton.h>
BluetoothSerial SerialBT;
using namespace ace_button;
Preferences pref;
// Replace with your network credentials
char ssid[] = "xxxx";
char pass[] = "12345678";
bool wifiConnected = false;
ButtonConfig config1;
AceButton button1(&config1);
ButtonConfig config2;
AceButton button2(&config2);
ButtonConfig config3;
AceButton button3(&config3);
ButtonConfig config4;
AceButton button4(&config4);
ButtonConfig config5;
AceButton button5(&config5);
ButtonConfig config6;
AceButton button6(&config6);
void handleEvent1(AceButton*, uint8_t, uint8_t);
void handleEvent2(AceButton*, uint8_t, uint8_t);
void handleEvent3(AceButton*, uint8_t, uint8_t);
void handleEvent4(AceButton*, uint8_t, uint8_t);
void handleEvent5(AceButton*, uint8_t, uint8_t);
void handleEvent6(AceButton*, uint8_t, uint8_t);
// Pin Definitions
#define pirPin 36
#define rcwlPin 4
#define irPin 35
#define sirenPin 23
#define emergencyLight 22
#define indoorLight1 18
#define indoorLight2 19
#define outdoorLight1 21
#define bannerLight 5
#define light2Pin 15
#define secureOnLight 17
#define wifiLED 2
#define buttonPin_1 13
#define buttonPin_2 12
#define buttonPin_3 14
#define buttonPin_4 27
#define buttonPin_5 26
#define buttonPin_6 25
#define buttonPin_7 33
//Define Blynk Virtual PIN
#define VPIN_Indoor1 V0
#define VPIN_Indoor2 V1
#define VPIN_Outdoor V2
#define VPIN_Emergency V3
#define VPIN_Banner V4
#define VPIN_OutdoorSensor V5
#define VPIN_DoorSensor V6
#define VPIN_IndoorSensor V7
#define VPIN_DoorMotion V8
#define VPIN_IndoorMotion V9
#define VPIN_SecureMode V10
#define VPIN_ModeName V11
#define VPIN_Light2 V12
char btCommand;
// State Variables
// Timing Constants
const unsigned long sirenOffTime = 5000;
const unsigned long rcwlSirenDuration = 5000;   // Siren stays on for 5 seconds
const unsigned long rcwlTimeout = 60000;
unsigned long lastReconnectAttempt = 0;
const unsigned long CONNECTION_TIMEOUT = 10000;
const unsigned long WIFI_RECONNECT_INTERVAL = 10000; // 10 seconds
unsigned long currentMillis =0;
unsigned long millis1 = 0;
unsigned long pirFirstDetected = 0;
unsigned long pirLastDetected = 0;
unsigned long rcwlSirenTime = 0;
bool secureModeOn = false;
bool pirActive = false;
bool rcwlActive = false;
bool rcwlSirenOn= false;
bool pirLightOn = false;
static bool sirenAlreadyOn = false;          // Track siren state
bool toggleState_1 = LOW;
bool toggleState_2 = LOW;
bool toggleState_3 = LOW;
bool toggleState_4 = LOW;
bool toggleState_5 = LOW;
bool toggleState_6 = LOW;
void handleBT(char btCommand){
    switch (btCommand) {
      case 'A':
      digitalWrite(indoorLight2, HIGH);
      Blynk.virtualWrite(VPIN_Indoor2, HIGH);
      toggleState_1 = HIGH;
      Serial.println("Indoor on");
      delay(50);
        break;
      case 'B':
      digitalWrite(indoorLight2, LOW);
      Blynk.virtualWrite(VPIN_Indoor2, LOW);
      Serial.println("Indoor off");
        break;
      case 'C':
      digitalWrite(light2Pin, HIGH);
      Blynk.virtualWrite(VPIN_Light2, HIGH);
      toggleState_2 = HIGH;
        break;
        case 'D':
      digitalWrite(light2Pin, LOW);
      Blynk.virtualWrite(VPIN_Light2, LOW);
        break;
        case 'E':
      digitalWrite(indoorLight1, HIGH);
      Blynk.virtualWrite(VPIN_Indoor1, HIGH);
      toggleState_3 = HIGH;
      delay(50);
        break;
        case 'F':
      digitalWrite(indoorLight1, LOW);
      Blynk.virtualWrite(VPIN_Indoor1, LOW);
      delay(50);
        break;
        case 'G':
        digitalWrite(outdoorLight1, HIGH);
        Blynk.virtualWrite(VPIN_Outdoor, HIGH);
        Serial.println("Outdoor on");
        toggleState_4 = HIGH;
        delay(50);
        break;
        case 'H':
        digitalWrite(outdoorLight1, LOW);
        Blynk.virtualWrite(VPIN_Outdoor, LOW);
        Serial.println("Outdoor off");
        delay(50);
        break;
        case 'I':
        digitalWrite(emergencyLight, HIGH);
        Blynk.virtualWrite(VPIN_Emergency, HIGH);
        toggleState_5 = HIGH;
        delay(50);
        break;
        case 'J':
        digitalWrite(emergencyLight, LOW);
        Blynk.virtualWrite(VPIN_Emergency, LOW);
        delay(50);
        break;
        case 'K':
        digitalWrite(bannerLight, HIGH);
        Blynk.virtualWrite(VPIN_Banner, HIGH);
        toggleState_6 = HIGH;
        delay(50);
        break;
        case 'L':
        digitalWrite(bannerLight, LOW);
        Blynk.virtualWrite(VPIN_Banner, LOW);
        break;
        case 'X':
        SerialBT.write('X');
        Serial.println("Secure_ON");
        secureModeOn = true;
        Serial.println("Secure Mode On");
        Blynk.virtualWrite(VPIN_SecureMode, secureModeOn);
        Blynk.virtualWrite(VPIN_ModeName, "Security ON");
        break;
        case 'Y':
        SerialBT.write('Y');
        Serial.println("Secure_OFF");
        Serial.println("Secure Mode Off");
        Blynk.virtualWrite(VPIN_ModeName, "Security OFF!");
        pirLightOn = false;
        rcwlSirenOn = false;
        break;
        default:
        break;
  unsigned long startAttemptTime = millis();
  connectToWiFi();
  Blynk.config(BLYNK_AUTH_TOKEN);
    config1.setEventHandler(handleEvent1);
    config2.setEventHandler(handleEvent2);
    config3.setEventHandler(handleEvent3);
    config4.setEventHandler(handleEvent4);
    config5.setEventHandler(handleEvent5);
    config6.setEventHandler(handleEvent6);
    button1.init(buttonPin_1);
    button2.init(buttonPin_2);
    button3.init(buttonPin_3);
    button4.init(buttonPin_4);
    button5.init(buttonPin_5);
    button6.init(buttonPin_6);
  SerialBT.begin("abcd");
  Serial.println("Printing Ready");
  pinMode(pirPin, INPUT);
  pinMode(rcwlPin, INPUT);
  pinMode(indoorLight1, OUTPUT);
  pinMode(light2Pin, OUTPUT);
  pinMode(indoorLight2, OUTPUT);
  pinMode(outdoorLight1, OUTPUT);
  pinMode(emergencyLight, OUTPUT);
  pinMode(bannerLight, OUTPUT);
  pinMode(sirenPin, OUTPUT);
  pinMode(secureOnLight, OUTPUT);
  pinMode(buttonPin_1, INPUT);
  pinMode(buttonPin_2, INPUT);
  pinMode(buttonPin_3, INPUT);
  pinMode(buttonPin_4, INPUT);
  pinMode(buttonPin_5, INPUT);
  pinMode(buttonPin_6, INPUT);
  pinMode(wifiLED, OUTPUT);
  digitalWrite(secureOnLight, LOW);
  digitalWrite(sirenPin, LOW);
  digitalWrite(wifiLED, LOW);
  delay(250);
  delay(100);
        Blynk.virtualWrite(VPIN_IndoorMotion, LOW);
        Blynk.virtualWrite(VPIN_IndoorSensor, LOW);
        Blynk.virtualWrite(VPIN_OutdoorSensor, LOW);
BLYNK_WRITE(VPIN_Indoor1) {
  toggleState_3 = param.asInt();
  digitalWrite(indoorLight1, toggleState_3);
// Blynk write handlers for relays
BLYNK_WRITE(VPIN_Indoor2) {
  toggleState_1 = param.asInt();
  digitalWrite(indoorLight2, toggleState_1);
BLYNK_WRITE(VPIN_Outdoor) {
  toggleState_4 = param.asInt();
  digitalWrite(outdoorLight1, toggleState_4);
BLYNK_WRITE(VPIN_Banner) {
  toggleState_6 = param.asInt();
  digitalWrite(bannerLight, toggleState_6);
BLYNK_WRITE(VPIN_Light2) {
  toggleState_2 = param.asInt();
  digitalWrite(light2Pin, toggleState_2);
BLYNK_WRITE(VPIN_Emergency) {
  toggleState_5 = param.asInt();
  digitalWrite(emergencyLight, toggleState_5);
BLYNK_WRITE(VPIN_SecureMode) {
  secureModeOn = param.asInt();
  if(secureModeOn){
  else{
  Blynk.virtualWrite(VPIN_ModeName, "Security OFF");
         pirLightOn = false;
  // Only run Blynk tasks if connected
  if (wifiConnected) {
    digitalWrite(wifiLED, HIGH);
  if (!wifiConnected && (millis() - lastReconnectAttempt >= WIFI_RECONNECT_INTERVAL)) {
    lastReconnectAttempt = millis();
    connectToWiFi();
  // Read sensor states
  pirActive = digitalRead(pirPin);
  rcwlActive = digitalRead(rcwlPin);
  button1.check();
  button2.check();
  button3.check();
  button4.check();
  button5.check();
  button6.check();
     // Offline mode control via Serial Bluetooth{ .... }
  if (SerialBT.available()) {
  btCommand = SerialBT.read();
  handleBT(btCommand);
  Serial.println(btCommand);
  if(secureModeOn){
  handlePIR();
  handleRCWL();
  digitalWrite(secureOnLight, HIGH);
  else {
  void handlePIR() {
  unsigned long currentMillis = millis();
  if (pirActive) {
    if (!pirLightOn) {
      // PIR is detected for the first time
      Serial.println("PIR detected");
      pirFirstDetected = currentMillis;
      millis1 = currentMillis;
      digitalWrite(sirenPin, HIGH);
      Blynk.virtualWrite(VPIN_DoorMotion, HIGH);
      pirLightOn = true;
  // If the PIR is no longer active
  if (!pirActive){
    if(!sirenAlreadyOn) {
    if (pirLightOn && (currentMillis - pirLastDetected) > sirenOffTime) {
      Blynk.virtualWrite(VPIN_DoorMotion, LOW);
      Serial.println("Light turned off due to PIR inactivity");
      pirLightOn = false;
      //pirLastDetected = currentMillis;
  // Update the last detected time when PIR is active
  if (pirActive) {
 void handleRCWL() {
  // Condition 1: If RCWL active and PIR not active
  if (rcwlActive && !pirActive && (currentMillis - pirLastDetected) > rcwlTimeout) {
    if (!rcwlSirenOn){
    Serial.println("RCWL detected without PIR");
    digitalWrite(sirenPin, HIGH); // Turn on siren
    Blynk.virtualWrite(VPIN_IndoorSensor, HIGH);
    rcwlSirenOn = true;
    rcwlSirenTime = millis();
if (rcwlSirenOn && !rcwlActive){
  if(millis() - rcwlSirenTime >= rcwlSirenDuration){
    if(!sirenAlreadyOn){
    Serial.println("RCWL only siren off");
    digitalWrite(sirenPin, LOW); // Turn off siren
  static unsigned long rcwlActiveStartTime = 0; // Track when RCWL became active
  if (rcwlActive && pirActive || rcwlActive && (currentMillis - pirLastDetected) <= rcwlTimeout) {   // add pir lastactive time
  rcwlActiveStartTime = currentMillis;    // Record when RCWL became active
    if (!sirenAlreadyOn) {
      Serial.println("RCWL detected with PIR active or recently active");
      Blynk.virtualWrite(VPIN_IndoorMotion, HIGH);
       sirenAlreadyOn = true;                  // Record siren state
  if (sirenAlreadyOn && !rcwlActive) {
    if (currentMillis - rcwlActiveStartTime >= 8000) {
      sirenAlreadyOn = false;      // Reset siren state
      Serial.println("Siren turned off after RCWL became inactive");
void handleEvent1(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT1");
  switch (eventType) {
    case AceButton::kEventPressed:
    toggleState_5 = !toggleState_5;
    Blynk.virtualWrite(VPIN_Emergency, toggleState_5);
        delay(50);
        break;
void handleEvent2(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT2");
    digitalWrite(indoorLight2, !toggleState_1);
    toggleState_1 = !toggleState_1;
    Blynk.virtualWrite(VPIN_Indoor2, toggleState_1);
        delay(50);
    break;
void handleEvent3(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT3");
    digitalWrite(light2Pin, !toggleState_2);
    toggleState_2 = !toggleState_2;
    Blynk.virtualWrite(VPIN_Light2, toggleState_2);
        delay(50);
    break;
void handleEvent4(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT4");
    digitalWrite(indoorLight1, !toggleState_3);
    toggleState_3 = !toggleState_3;
    Blynk.virtualWrite(VPIN_Indoor1, toggleState_3);
        delay(50);
    break;
void handleEvent5(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT5");
    digitalWrite(outdoorLight1, !toggleState_4);
    toggleState_4 = !toggleState_4;
    Blynk.virtualWrite(VPIN_Outdoor, toggleState_4);
        delay(50);
    break;
void handleEvent6(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT6");
    digitalWrite(bannerLight, !toggleState_6);
    toggleState_6= !toggleState_6;
    Blynk.virtualWrite(VPIN_Banner, toggleState_6);
        delay(50);
    break;
void connectToWiFi() {
  WiFi.begin(ssid, pass);
  Serial.print("Connecting to Wi-Fi");
  for (int i = 0; i < 10; i++) { // Try for 10 seconds
    if (WiFi.status() == WL_CONNECTED) {
      wifiConnected = true;
      Serial.println("\nWi-Fi Connected!");
      Blynk.connect();
      return;
    Serial.print(".");
  Serial.println("\nWi-Fi Connection Failed!");
There’s so many issues with this code it’s difficult to know where to begin.
What type of Blynk subscription do you have (Free, Maker, Pro)?
If it’s a Free account then what does your billing screen show about the maximum number of available templates?
I don’t see any notification code in this sketch, are you doing this via automations, or do you mean something other than notifications?
Yes, I set automation when motion detect it will send a notification. I use free plan, 9 templates available out of 10. There I found I have used 30,000 messeges. But I dont understand why this happened? Please suggest me where have to modify my program.
Sir please help me.
Every message between the Blynk server and your device(s) counts towards your 30,000 message monthly allowance.
Every time your device does a Blynk.virtualWrite counts as message.
Every time you press a button in the app and BLYNK_WRITE(vPin) is triggered counts as a message.
30,000 messages per month equals around 1,000 messages per day.
There are 86,400 seconds in a day, so you can afford to send a message about every 90 seconds on average. From your description, you used-up your monthly allowance in a few hours.
Upgrading to a Pro subscription would remove the monthly message limit. If you can’t afford that then you should probably look a an alternative platform to Blynk.
