Hi, here are the details of my project first,
Hardware: NodMCU ESP12E
I am using the new blynk 2.0 to control a led bulb. When I had used only one blynk.write to check if it is working, all went good. But when i started to add more blynk.write’s, the board was not reflecting as online in the app/web-dashboard. I am unable to understand why this is happening. Could anyone please help me out1
Code:
#define BLYNK_TEMPLATE_ID "TMPL97m4kvuI"
#define BLYNK_DEVICE_NAME "Smart Home 2"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
//#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
#include "BlynkEdgent.h"
pinMode(5, OUTPUT);
pinMode(4, OUTPUT);
pinMode(14, OUTPUT);// Initialise digital pin 2 as an output pin
delay(100);
BLYNK_WRITE(V0) // Executes when the value of virtual pin 0 changes
if(param.asInt() == 1)
// execute this code if the switch widget is now ON
digitalWrite(5,HIGH); // Set digital pin 2 HIGH
// execute this code if the switch widget is now OFF
digitalWrite(5,LOW); // Set digital pin 2 LOW
BLYNK_WRITE(V1) // Executes when the value of virtual pin 0 changes
digitalWrite(4,HIGH); // Set digital pin 2 HIGH
digitalWrite(4,LOW); // Set digital pin 2 LOW
BLYNK_WRITE(V2) // Executes when the value of virtual pin 0 changes
digitalWrite(14,HIGH); // Set digital pin 2 HIGH
digitalWrite(14,LOW); // Set digital pin 2 LOW
BlynkEdgent.run();
