one question if I may ask anymore - Led 0 and Led 11 on the neopixel strip lights green - if I push the touchsensor it turns to red, but if I release it turns back to green, but… if relay on = led green / if relay off = led red
Any tip for me?
void checkPhysicalButton2()
if (digitalRead(btnTwoPin) == LOW) {
if (btnTwoState != LOW) {
// Toggle LED state
relayTwoState = !relayTwoState;
digitalWrite(relayTwoPin, relayTwoState);
// Update Button Widget
Blynk.virtualWrite(V1, relayTwoState);
btnTwoState = LOW;
strip.setPixelColor(11, 0, 127, 0);
strip.show();
btnTwoState = HIGH;
strip.setPixelColor(11, 127, 0, 0);
strip.show();
I check the state of the of the “relayOneState” - this gives a number of 0 or 1, and if the “relayOneState == 1” than turn Pixel 1 to green - if not turn to red. This have to go inside of the “checkPhysikalButton”
maybe someone got a cleaner and smother idea for my sketch
#include <Adafruit_NeoPixel.h>
const int relayOnePin = 12; //connected to nodeMCU Pin D6 and relay IN1
const int relayTwoPin = 14; //connected to nodeMCU Pin D5 and relay IN2
const int btnOnePin = 13; //connected to nodeMCU Pin D7 Touch Sensor 1 IN
const int btnTwoPin = 15; //connected to nodeMCU Pin D8 Touch Sensor 2 IN
const int neoPin = 5; // WS2812b connectet to nodeMCU Pin D1
Adafruit_NeoPixel strip = Adafruit_NeoPixel(12, neoPin, NEO_GRB + NEO_KHZ800); //Set the Neopixel Strip to 12 Pixels on pin 5
// Your Wifi Credentials and Auth Tokens
char auth[] = "x";
char ssid[] = "x";
char pass[] = "x";
char server[] ="x";
void checkPhysicalButton1();
void checkPhysicalButton2();
int relayOneState = LOW;
int btnOneState = HIGH;
int relayTwoState = LOW;
int btnTwoState = HIGH;
BLYNK_CONNECTED()
Blynk.syncVirtual(V0);
Blynk.syncVirtual(V1);
// Button 1
BLYNK_WRITE(V0) {
relayOneState = param.asInt();
digitalWrite(relayOnePin, relayOneState);
if (digitalRead(btnOnePin) == LOW) {
if (btnOneState != LOW) {
relayOneState = !relayOneState;
Blynk.virtualWrite(V0, relayOneState);
btnOneState = LOW;
else {
btnOneState = HIGH;
//Led 1 Color Change
if (relayOneState == 1) {
strip.setPixelColor(0, 64, 224, 208);
strip.show();
else {
strip.setPixelColor(0, 127, 0, 0);
strip.show();
// Button 2
BLYNK_WRITE(V1) {
relayTwoState = param.asInt();
btnTwoState = LOW;
else {
btnTwoState = HIGH;
//LED 2 Color Change
if (relayTwoState == 1) {
strip.setPixelColor(11, 64, 224, 208);
strip.show();
else {
strip.show();
Blynk.begin(auth, ssid, pass, server);
strip.begin();
strip.show();
strip.setBrightness(64);
pinMode(relayOnePin, OUTPUT);
pinMode(btnOnePin, INPUT_PULLUP);
pinMode(relayTwoPin, OUTPUT);
pinMode(btnTwoPin, INPUT_PULLUP);
timer.setInterval(100L, checkPhysicalButton1);
timer.setInterval(130L, checkPhysicalButton2);
